7i76e Stepgen problem
01 Mar 2022 11:55 #236095
by stes
7i76e Stepgen problem was created by stes
I'm having a problem with stepgen3. All other step generators work fine with my ihsv57 servo. I'm quite sure that the problems is not in the servo wiring or settings. I measured the voltages on stepgen4 and got 5v for step and dir+, and 0v for step and dir- when linux cnc is off, and when linux cnc is on, its the other way round.
But for stepgen 0, 1, 2 and 3 i get 0v for step and dir+, and 20-60mv for step dir-, whether linux cnc is on or off it doesn't affect the voltages. and all the stepgens can move the servo except stepgen3. What could cause this?
01 Mar 2022 14:13 #236114
Replied by PCW on topic 7i76e Stepgen problem
Sounds like the driver for STEP0+ .. STEP3+ (74ACT541 U19)
is damaged.
is damaged.
01 Mar 2022 15:07 #236115
by stes
Replied by stes on topic 7i76e Stepgen problem
Thought I was careful installing it.
Is this the part?
TSSOP-20 package?
01 Mar 2022 19:29 #236125
Yes TSSOP-20
31 Mar 2022 14:38 #238908
by stes
I changed the U19 chip but voltages are still the same.
01 Apr 2022 15:27 #238994
by stes
Now when I measured Vcc on U19 is 5v.
For stepgen 0 to 3 dir- and step- is 20 to 60mV, dir+ and step+ 0V.
For stepgen 4 step- and dir- 0V, step+ and dir+ 5V.
I didn't connect anything on the board after changing the chip except power and Ethernet cable. Could there be some other issue than U19?
01 Apr 2022 15:36 #238996
If you connected say 24V to the step/dir pins, you may have
blown up the 27 ohm resistor networks between U19 and the
terminal blocks.
terminal blocks.
01 Apr 2022 16:18 #239001
by stes
Thanks. Those resistor networks are RN3, 7, 24 and 32? What packages are those? I will try to measure the voltages from the U19 directly and if it's ok then I will change those resistors.
01 Apr 2022 17:29 #239007
Yes RN3,7,24,32 27 Ohm MNR14 (1206)
Time to create page: 0.427 seconds
