8i20
01 Mar 2022 23:40 - 02 Mar 2022 00:14 #236145 by PCW
Replied by PCW on topic 8i20
Does the init cycle run without fault?
What I am getting at is that you may get faults due to instability,
either in LinuxCNCs PID = LinuxCNC PID tuning issues or in the 8I20.
If you cannot set a static current in the 8i20 without fault, its likely the
8I20s current loop PI gains are too high for your motor.
Last edit: 02 Mar 2022 00:14 by PCW.
The following user(s) said Thank You: dkraft
02 Mar 2022 00:14 #236146 by andypugh
Replied by andypugh on topic 8i20
setp [HMOT](CARD0).0.8i20.0.0.current-maxlim 0.020
setp [HMOT](CARD0).0.8i20.0.0.current-minlim -0.020
Is this just for testing? I have forgotten how the calculations work, but this seems odd.
I run both my machines with 8i20, but as they have resolvers the configs won't transfer straight across.
net x-meas-angle bldc.0.rotor-angle => hm2_5i23.0.8i20.0.2.angle
setp hm2_5i23.0.8i20.0.2.current-maxlim 7.5
setp hm2_5i23.0.8i20.0.2.current-minlim -7.5
net x-cmd  joint.0.motor-pos-cmd => pid.0.command
net x-vel-cmd joint.0.vel-cmd => pid.0.command-deriv
net x-fb hm2_5i23.0.resolver.01.position pid.0.feedback joint.0.motor-pos-fb
net x-vel-fb hm2_5i23.0.resolver.01.velocity pid.0.feedback-deriv
setp hm2_5i23.0.resolver.01.velocity-scale -1
net x-pid pid.0.output => hm2_5i23.0.8i20.0.2.current
#12 motor 49 pulley 5 leadscrew pitch
setp hm2_5i23.0.resolver.01.scale -1.2244898
net amp-enable-and-DC-good pid.0.enable
setp pid.0.Pgain [JOINT_0]PGAIN
setp pid.0.Igain [JOINT_0]IGAIN
setp pid.0.Dgain [JOINT_0]DGAIN
setp pid.0.bias [JOINT_0]BIAS
setp pid.0.FF0 [JOINT_0]FF0
setp pid.0.FF1 [JOINT_0]FF1
setp pid.0.FF2 [JOINT_0]FF2
setp pid.0.deadband [JOINT_0]DEADBAND
setp pid.0.maxoutput [JOINT_0]MAXOUTPUT
setp bldc.0.scale -16777216
setp bldc.0.poles 6
setp bldc.0.lead-angle 0
setp bldc.0.encoder-offset -950000
Try with the max and min current matching the nvmaxcurrent (7.5A = 0x2EE, which you seem to have)
02 Mar 2022 13:16 #236166 by dkraft
Replied by dkraft on topic 8i20
Its the init that trips it. struggling with a way to diagnose it.
02 Mar 2022 14:01 #236172 by andypugh
Does it always trigger? Or is it OK the second time? I am wondering about transient effects as the rotor snaps in to phase.
I guess you have tried both higher and lower initvalue values?
02 Mar 2022 14:01 #236173 by dkraft
How do you drive the input enable and read the fault out physical pins on the 8i20? Do you setup pins from the driver board?
Currently testing, I'm driving input enable from 5v off the serial connector.. not sure if that is trouble.
02 Mar 2022 17:57 - 02 Mar 2022 23:10 #236201 by dkraft
Figured out the tripping error. Too low impedance on the motor detects as a short apparently.
250Kv motors will never work no matter how low you try to drive it ;)
Thanks!
Last edit: 02 Mar 2022 23:10 by dkraft.
02 Mar 2022 18:12 #236202 by andypugh
Are these RC aircraft motors?
02 Mar 2022 18:47 #236205 by PCW
Yes I forgot to ask this, what type of motor and perhaps more important, what is the motor inductance?
The 8I20 is intended for medium/high inductance motors (standard AC 230V servo motors)
02 Mar 2022 23:09 #236225 by dkraft
yes. I thought I'd be clever and debug with a low inductance motor, didn't work. got it working with a washing machine motor though..
Moving on to the yaskawa servo motors now.
Your help with the commutation signals was crucial. Thank You.
Last piece was bldc.init ;)
15 Mar 2022 12:34 #237321 by dkraft
How can I get my encoder offset ?
I'm thinking it's aligned with the "U+, VW-" method, then average the 6 positions found modulus encoder scale / poles...
(I hacked a CMT102 on a servo with 6 poles)
Moderators: PCWjmelson
Time to create page: 0.172 seconds
