7i96 with stepper motors
10 Mar 2022 22:07 - 10 Mar 2022 22:07 #236897
by Nate
7i96 with stepper motors was created by Nate
good afternoon i was wondering if anyone could tell me why i can jog in all directions but when i tell it to home nothing happens
Last edit: 10 Mar 2022 22:07 by Nate.
10 Mar 2022 23:43 #236903
by BigJohnT
Replied by BigJohnT on topic 7i96 with stepper motors
10 Mar 2022 23:48 #236904
Replied by andypugh on topic 7i96 with stepper motors
I think this is because all the joints have a HOME_SEQUENCE of 2. HOME_SEQUENCE needs to start at -1, 0 or 1.good afternoon i was wondering if anyone could tell me why i can jog in all directions but when i tell it to home nothing happens
14 Mar 2022 15:11 #237208
by Nate
Replied by Nate on topic 7i96 with stepper motors
good morning i got that fixed now when i open up my plasmac i get this error report can you help me solve it?
- Thank you received: 5948
14 Mar 2022 16:33 #237213
Replied by tommylight on topic 7i96 with stepper motors
What error?
14 Mar 2022 16:39 #237214
by Nate
sorry it did not post the error report
14 Mar 2022 16:40 #237215
by Nate
lets try this again
14 Mar 2022 16:41 #237216
by Nate
not letting me insert report file so i will try this way
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.8.0~pre1
Machine configuration directory is '/home/nathan/linuxcnc/configs/plasmac'
Machine configuration file is 'plasmac.ini'
INIFILE=/home/nathan/linuxcnc/configs/plasmac/plasmac.ini
VERSION=1.1
PARAMETER_FILE=imperial_parameters.txt
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=XYZ
KINEMATICS=trivkins coordinates=XYZ
Starting LinuxCNC...
twopass:invoked with <> options
twopass:found ./plasmac.hal
twopass:found ./plasmac.tcl
twopass:found ./plasmac_connections.hal
twopass: load_the_modules cmd=<orig_loadrt motmod servo_period_nsec=1000000 num_joints=3 {num_spindles=3 3}>
waitpid failed /usr/bin/rtapi_app motmod
/usr/bin/rtapi_app exited without becoming ready
insmod for motmod failed, returned -1
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 10.10.10.10: Hardware address: 00:60:1b:16:01:99
hm2_eth: discovered 7I96
hm2/hm2_7i96.0: Smart Serial Firmware Version 43
hm2/hm2_7i96.0: 51 I/O Pins used:
hm2/hm2_7i96.0: IO Pin 000 (TB3-01): IOPort
hm2/hm2_7i96.0: IO Pin 001 (TB3-02): IOPort
hm2/hm2_7i96.0: IO Pin 002 (TB3-03): IOPort
hm2/hm2_7i96.0: IO Pin 003 (TB3-04): IOPort
hm2/hm2_7i96.0: IO Pin 004 (TB3-05): IOPort
hm2/hm2_7i96.0: IO Pin 005 (TB3-06): IOPort
hm2/hm2_7i96.0: IO Pin 006 (TB3-07): IOPort
hm2/hm2_7i96.0: IO Pin 007 (TB3-08): IOPort
hm2/hm2_7i96.0: IO Pin 008 (TB3-09): IOPort
hm2/hm2_7i96.0: IO Pin 009 (TB3-10): IOPort
hm2/hm2_7i96.0: IO Pin 010 (TB3-11): IOPort
hm2/hm2_7i96.0: IO Pin 011 (TB3-13/TB3-14): SSR #0, pin Out-00 (Output)
hm2/hm2_7i96.0: IO Pin 012 (TB3-15/TB3-16): SSR #0, pin Out-01 (Output)
hm2/hm2_7i96.0: IO Pin 013 (TB3-17/TB3-18): SSR #0, pin Out-02 (Output)
hm2/hm2_7i96.0: IO Pin 014 (TB3-19/TB3-20): SSR #0, pin Out-03 (Output)
hm2/hm2_7i96.0: IO Pin 015 (TB3-21/TB3-22): SSR #0, pin Out-04 (Output)
hm2/hm2_7i96.0: IO Pin 016 (TB3-23/TB3-24): SSR #0, pin Out-05 (Output)
hm2/hm2_7i96.0: IO Pin 017 (TB1-02/TB1-03): StepGen #0, pin Step (Output)
hm2/hm2_7i96.0: IO Pin 018 (TB1-04/TB1-05): StepGen #0, pin Direction (Output)
hm2/hm2_7i96.0: IO Pin 019 (TB1-08/TB1-09): StepGen #1, pin Step (Output)
hm2/hm2_7i96.0: IO Pin 020 (TB1-10/TB1-11): StepGen #1, pin Direction (Output)
hm2/hm2_7i96.0: IO Pin 021 (TB1-14/TB1-15): StepGen #2, pin Step (Output)
hm2/hm2_7i96.0: IO Pin 022 (TB1-16/TB1-17): StepGen #2, pin Direction (Output)
hm2/hm2_7i96.0: IO Pin 023 (TB1-20/TB1-21): StepGen #3, pin Step (Output)
hm2/hm2_7i96.0: IO Pin 024 (TB1-22-TB1-23): StepGen #3, pin Direction (Output)
hm2/hm2_7i96.0: IO Pin 025 (TB2-01/TB2-03): StepGen #4, pin Step (Output)
hm2/hm2_7i96.0: IO Pin 026 (TB2-04/TB2-05): StepGen #4, pin Direction (Output)
hm2/hm2_7i96.0: IO Pin 027 (TB2-07/TB2-08): Encoder #0, pin A (Input)
hm2/hm2_7i96.0: IO Pin 028 (TB2-10/TB2-11): Encoder #0, pin B (Input)
hm2/hm2_7i96.0: IO Pin 029 (TB2-13/TB2-14): Encoder #0, pin Index (Input)
hm2/hm2_7i96.0: IO Pin 030 (TB2-16/TB2-17): IOPort
hm2/hm2_7i96.0: IO Pin 031 (TB2-18/TB2-19): IOPort
hm2/hm2_7i96.0: IO Pin 032 (internal): IOPort
hm2/hm2_7i96.0: IO Pin 033 (internal): SSR #0, pin AC Ref (internal) (Output)
hm2/hm2_7i96.0: IO Pin 034 (P1-01): IOPort
hm2/hm2_7i96.0: IO Pin 035 (P1-02): IOPort
hm2/hm2_7i96.0: IO Pin 036 (P1-03): IOPort
hm2/hm2_7i96.0: IO Pin 037 (P1-04): IOPort
hm2/hm2_7i96.0: IO Pin 038 (P1-05): IOPort
hm2/hm2_7i96.0: IO Pin 039 (P1-06): IOPort
hm2/hm2_7i96.0: IO Pin 040 (P1-07): IOPort
hm2/hm2_7i96.0: IO Pin 041 (P1-08): IOPort
hm2/hm2_7i96.0: IO Pin 042 (P1-09): IOPort
hm2/hm2_7i96.0: IO Pin 043 (P1-11): IOPort
hm2/hm2_7i96.0: IO Pin 044 (P1-13): IOPort
hm2/hm2_7i96.0: IO Pin 045 (P1-15): IOPort
hm2/hm2_7i96.0: IO Pin 046 (P1-17): IOPort
hm2/hm2_7i96.0: IO Pin 047 (P1-19): IOPort
hm2/hm2_7i96.0: IO Pin 048 (P1-21): IOPort
hm2/hm2_7i96.0: IO Pin 049 (P1-23): IOPort
hm2/hm2_7i96.0: IO Pin 050 (P1-25): IOPort
hm2/hm2_7i96.0: registered
hm2_eth: HostMot2 ethernet driver unloaded
hm2: unloading
Debug file information:
Note: Using POSIX realtime
`3 3' invalid for parameter `num_spindles=3 3'30780
Stopping realtime threads
Unloading hal components
Info report created by linuxcnc_info:
The file: /tmp/linuxcnc_info.txt
can be posted to a forum or a web site like:
pastebin.com
in order to provide information about the linuxcnc
system and configuration.
Date: Mon Mar 14 09:08:29 MDT 2022
UTC Date: Mon Mar 14 15:08:29 UTC 2022
this program: /usr/bin/linuxcnc_info
uptime: 09:08:29 up 3 days, 22:14, 1 user, load average: 0.16, 0.32, 0.24
lsb_release -sa: LinuxMint Linuxcnc Uspace Powered by Linux Mint 19.2 Tina 19.2 tina
which linuxcnc: /usr/bin/linuxcnc
pwd: /home/nathan/linuxcnc/configs/plasmac
USER: nathan
LOGNAME: nathan
HOME: /home/nathan
EDITOR:
VISUAL:
LANGUAGE: en_US
TERM: dumb
COLORTERM:
DISPLAY: :0
DESKTOP: mate
display size: 1280x800 pixels (338x211 millimeters)
PATH: /usr/bin:/home/nathan/linuxcnc/configs/plasmac/bin:/usr/bin:/home/nathan/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games
uname items:
nodename -n: nathan-LifeBook-T5010
kernel-name -s: Linux
kernel-vers -v: #1 SMP PREEMPT RT Thu Mar 5 00:02:34 AEDT 2020
machine -m: x86_64
processor -p: x86_64
platform -i: x86_64
oper system -o: GNU/Linux
/proc items:
cmdline: BOOT_IMAGE=/boot/vmlinuz-4.19.106-rt44-lcnc root=UUID=c74e3fa1-d9ad-4823-8533-d942bb41472e ro quiet splash vt.handoff=1
model name: Intel(R) Core(TM)2 Duo CPU P8600 @ 2.40GHz
cores: 2
cpu MHz: 1595.975
parport:
serial: 0000-0000 : serial
Versions:
gcc: gcc (Ubuntu 7.5.0-3ubuntu1~18.04) 7.5.0
python: Python 2.7.17
git: git version 2.17.1
git commit: NA
tcl: 8.6
tk: 8.6
glade: not_in_PATH
glade-gtk2: not_in_PATH
linuxcnc_var all:
LINUXCNCVERSION: 2.8.0~pre1
LINUXCNC_AUX_GLADEVCP: /usr/share/linuxcnc/aux_gladevcp
LINUXCNC_AUX_EXAMPLES: /usr/share/linuxcnc/aux_examples
REALTIME: /etc/init.d/realtime
RTS: uspace
HALLIB_DIR: /usr/share/linuxcnc/hallib
dpkg -l '*linuxcnc*':
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
un linuxcnc <none> <none> (no description available)
un linuxcnc-dev <none> <none> (no description available)
un linuxcnc-doc <none> <none> (no description available)
ii linuxcnc-doc-en 1:2.8.0~pre1.5853.g0eab7e707 all motion controller for CNC machines and robots (English documentation)
un linuxcnc-sim <none> <none> (no description available)
un linuxcnc-sim-dev <none> <none> (no description available)
ii linuxcnc-uspace 1:2.8.0~pre1.5853.g0eab7e707 amd64 motion controller for CNC machines and robots
ii linuxcnc-uspace-dev 1:2.8.0~pre1.5853.g0eab7e707 amd64 PC based motion controller for real-time Linux
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
VERSION=1.1
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=XYZ
hm2: unloading
pastebin.com
USER: nathan
LOGNAME: nathan
HOME: /home/nathan
EDITOR:
VISUAL:
LANGUAGE: en_US
TERM: dumb
COLORTERM:
DISPLAY: :0
DESKTOP: mate
uname items:
machine -m: x86_64
platform -i: x86_64
/proc items:
cores: 2
cpu MHz: 1595.975
parport:
Versions:
git commit: NA
tcl: 8.6
tk: 8.6
glade: not_in_PATH
linuxcnc_var all:
RTS: uspace
14 Mar 2022 17:05 #237220
From the error:The brackets around spindle num are not allowed, and only one of 3 is OK so delete the second one.
That is in the beginning of the .hal file.
14 Mar 2022 19:43 #237228
by Nate
here is my files i am not finding that
Time to create page: 0.167 seconds
