7i96 P1 Expansion
14 Mar 2022 08:55 #237194
by Hendrixx
7i96 P1 Expansion was created by Hendrixx
Is it possible to add an MPG to 7i96 through the P1 expansion connector
- Thank you received: 5946
14 Mar 2022 09:38 #237197
Replied by tommylight on topic 7i96 P1 Expansion
Pretty sure it is, well i am sure it is, two ways, software and hardware encoder, the latter will probably require flashing the Mesa board.
Thinking a bit more, i will let this to PCW to answer, he is the Mesa Sensei.
14 Mar 2022 20:13 #237231
Replied by PCW on topic 7i96 P1 Expansion
You can add a MPG counter on P1 but note that you have to be
careful to not connect any pin on P1 to a voltage outside the 0 to 5V
range or to frame GND (which often has a volt or two of HF AC noise
so can drive excess current into the P1 pins when negative) This will
damage the BUS switch or the FPGA.
Here is a configuration that includes 4 MPG encoder inputs on the first
8 pins of P1 (26 pin header pins 1,2,3,4,5,6,7,8):
22 Jun 2022 20:04 #245615
by MartynT
Replied by MartynT on topic 7i96 P1 Expansion
I actually managed to get this working last year. A lot of reading others posts and google but I got there in the end. I did communicate with someone outside the LCNC community about various aspects of his solution. He was using the same type of jog pendant as I bought online and you can find his description on his website wapl.es/cnc/2020/02/23/linuxcnc-jog-wheel-setup.html. The problem with these generic Chinese pendants is that the wiring is not always identical so a bit of work with the multimeter is required. I've attached my finished mpg.hal file which should be referenced in the INI file.
With reference to PCW's answer, I was intrigued as to his solution as he is from Mesa but although recognising the .bit file (but unreadable for me), I hadn't seen that example in the 7i96.zip file I downloaded from Mesa, I used the 7i96_5abob_d (pin file is readable). The other vhd file is also an unknown to me apart from the fact that it belongs with the included source files.
I recently installed inductive limit switches (NPN NC) which physically seem to work well with the 7i96 but I'm having some trouble with "joint # on limit switch errors" on all three joints when turning it on in the GUI. Must be something in the config and I might have to ask for help in the forum myself.
22 Jun 2022 21:55 #245616
The advantage of the bitfile I provided is that it can use 1X mode on
the MPG encoders which is better for 100 PPR MPGs with detents
as you get 1 increment per detent.
Time to create page: 0.165 seconds
