Run Mesa 7i76e + 7i85 with 3 servos and 1 stepper motor
30 Mar 2022 20:18 #238817
Replied by andypugh on topic Run Mesa 7i76e + 7i85 with 3 servos and 1 stepper motor
I think that would be a good starting point. Note that that routine has an arm in-out and a locking pin, so your system might end up simpler.
Look at the HAL file too.
github.com/LinuxCNC/linuxcnc/tree/master...smach/VMC_toolchange
toolchange_index.hal is likely to be close.
30 Mar 2022 20:21 #238818
by MarcusM
Replied by MarcusM on topic Run Mesa 7i76e + 7i85 with 3 servos and 1 stepper motor
Ok, thank you so much.
In the example toolchange.ngc there has to be set #<tool_in_spindle> and other parameters. I could'nt find, where they has to be/will be defined.
30 Mar 2022 20:32 #238820
#<tool_in_spindle> is created by the prolog routine in the tool remap.
This line in the INI file of that sample:
Tells the system that when it sees an M6 it should run a (library) routine called "change_prolog", then run the toolchange.ngc file, then the "change_epilog"
REMAP= M6 modalgroup=6 prolog=change_prolog ngc=toolchange epilog=change_epilog
30 Mar 2022 20:34 #238821
by MarcusM
Got it. Thank you
31 Mar 2022 21:34 #238939
by MarcusM
Ok. I reviewed all my macros and stuff. The homing is now directly from the carousel component. And seems to work so far.
I also tried to understand the manual pages of the M6 remap with prolog and epilog.
What is not ok in the moment: #<tool_in_spindle> always show -1, even if I run T2M6 for example. The screen also shows T0, so I think, the M6 will not end sucessful.
31 Mar 2022 21:40 #238942
What happens if you use M61 to change the tool in spindle without M6?
linuxcnc.org/docs/stable/html/gcode/m-code.html#mcode:m61
31 Mar 2022 21:44 #238943
by MarcusM
The tool appears in the screen. M61 Q3 e.g. will correctly show T3 as selected tool.
The parameter tool_in_spindle get the correct value also.
31 Mar 2022 22:11 #238951
Then I suspect that somewhere in the remapped G-code routine the (default, un-remapped) M6 is not being run.
Can you trace the programme logic to work out under what circumstances that could happen?
31 Mar 2022 22:15 - 31 Mar 2022 22:15 #238954
by MarcusM
I add quick and dirty the M61 command to the toolchange.ngc file. Indeed, in this macro there is no M6 command.
Last edit: 31 Mar 2022 22:15 by MarcusM.
31 Mar 2022 22:28 #238955
You can (and probably should) use M6. Remap knows when the remapped code is used in the remap and runs the normal version.
The following user(s) said Thank You: MarcusM
Time to create page: 0.271 seconds
