Mesa 5i25 + 7i77 + 7i78
23 Mar 2022 16:31 - 23 Mar 2022 16:31 #238114
Replied by PCW on topic Mesa 5i25 + 7i77 + 7i78
first download the firmware in the 5i25.zip file:
www.mesanet.com/software/parallel/5i25.zip
unzip this archive in your home or home/Downloads directory and cd to
configs/hostmot2
then
sudo mesaflash --device 5i25 --write 5i25_7i77_7i78.bit
sudo mesaflash --device 5i25 --reload
configs/hostmot2
then
Last edit: 23 Mar 2022 16:31 by PCW.
24 Mar 2022 10:28 #238209
by Marçal
Replied by Marçal on topic Mesa 5i25 + 7i77 + 7i78
Thank you very much! As you thought the problem was that the firmware was not updated. Thanks to you I managed to run the z axis. I'll keep working on the plasma cutting machine.
01 Apr 2022 09:33 #238977
by Marçal
I am not sure whether I have to start another thread or not. As I mentioned in the previous messages, I have already managed to make the z-axis work. Nonetheless, I would like to add some PNP inductive sensors for home and limit. And then add THCAD 5 for the plasma torch high control. The z-axis works with a stepper motor + mesa 7i78 + 5i25. My question is regarding the wiring of the inductive sensors and the THCAD. Can I wire them directly to the 7i78 or do I need to buy another daughtercard?
Thanks in advance.
Thanks in advance.
01 Apr 2022 15:17 #238993
by Marçal
Sorry, now I have another problem. The program I had for the servo motors (x and y axis and 7i77), does not work anymore. The CR16 red light from the 7i77 is on.
I tried to merge the ini and hal files from the program I made for the z axis (stepper motor and 7i78) and the one I got for the x and y axis but it did not work. Thus, I deleted the lines I had copied from the z axis hal and ini and I left it like it was before the first modification. I am not sure if it is what caused the problem or not. Because I tried to use the pncconf and it does not detect the 7i77 anymore.
I've attached the ini and hal file that were given to me from the x and y axis.
Thank you in advance.
01 Apr 2022 15:39 #238997
The hal file is empty
01 Apr 2022 15:56 - 01 Apr 2022 15:58 #238998
by Marçal
Sorry, I think is this one
Last edit: 01 Apr 2022 15:58 by Marçal.
01 Apr 2022 16:21 #239002
That's a parallel port configuration
04 Apr 2022 09:53 #239231
by Marçal
Then it was the previous one but I did something wrong that deleted the content. Is there any chance to recover previous versions of the hal file?
04 Apr 2022 14:48 #239258
You might look in the ~/linuxcnc/configs/my_LinuxCNC_machine directory,
pncconf puts configuration files there.
Time to create page: 0.167 seconds
