7i76 firmware update
23 Mar 2022 14:12 #238105
by roland
7i76 firmware update was created by roland
I have a quite old 7i76 with firmware Rev.6.
So I would like to update the firmware.
As far as I know I need this software package:
www.mesanet.com/software/parallel/sserial.zip
Unfortunately the link is broken.
Where can I get the software to update the 7i76 to a current firmware?
23 Mar 2022 14:21 #238106
Replied by PCW on topic 7i76 firmware update
The following user(s) said Thank You: roland
23 Mar 2022 14:27 - 23 Mar 2022 15:34 #238107
by roland
Replied by roland on topic 7i76 firmware update
This download link works. Thanks!
Update to Rev.15 was successful
Last edit: 23 Mar 2022 15:34 by roland.
- robertspark
- Thank you received: 216
28 Mar 2022 20:19 #238546
by robertspark
Replied by robertspark on topic 7i76 firmware update
how does one update the firmware on a 7i76?
I've got one connected to a 7i92H and there did not seem to be anything in the 7i76 user manual on updating the firmware.
www.mesanet.com/pdf/parallel/7i76man.pdf
28 Mar 2022 20:26 #238548
You should not need to update the firmware unless you have very old
firmware (and you are getting warinig messages of this from LinuxCNC)
If you are getting warnings from LinuxCNC, the utilities to update the firmware
and instructions are in:
www.mesanet.com/software/parallel/sserial.tgz
The following user(s) said Thank You: robertspark
- robertspark
28 Mar 2022 20:53 #238551
by robertspark
Its not that old, I was more just curious (just swapped my 7i76E firmware to the 7i76e_7i76x1_5abobpD .... very easy as I was looking for some PWM outputs, saved me a load of work there thanks very much as the Xilinx ISE was not loading on my windows machine.... 6gb download was in progress when I found the bit + pin file and uploaded it).
the 7i76 just has a lathe on it so is very simple config.
Time to create page: 0.123 seconds
