5i23 5 volt power
26 Mar 2022 13:49 #238399
by billykid
5i23 5 volt power was created by billykid
as before i had 7i80 7i37 7i30 getting the 5 volts from a separate 5 amp power supply.
now I have replaced the 7i80 with the 5i23 since it has 400 milliamps per connector I would like to use that.
or better to use a separate power supply and remove the jumpers W1 and W2 so as not to mix the sources?
thanks
thanks
26 Mar 2022 14:51 #238401
Replied by PCW on topic 5i23 5 volt power
I would use the 5I23 5V especially for step/dir systems
that have low current draw.
26 Mar 2022 15:07 #238403
by billykid
Replied by billykid on topic 5i23 5 volt power
an external power supply is better I have 3 encoders and the thcad connected, only the 7i30 does not have the jumper cable / p1 to disconnect pin 49, I remove the 3.3 / 5volt jumper on the 5i23 ?
26 Mar 2022 16:10 #238407
Yes, removing that jumper disconnects pin 49
The following user(s) said Thank You: billykid
Time to create page: 0.181 seconds
