Mesa 7i92M+7i85+7i78 'hm2_7i92.0.dpll.01.timer-us' not found
- heinzischmirtzi
20 Apr 2022 09:36 - 20 Apr 2022 10:57 #240725
by heinzischmirtzi
I've read quite a lot of forum posts lately. But my Problem seems to be a bit more specific.
I've got a 7i92 and connected a 7i78 on P1 and a 7i85 on P2 and uploaded a self compiled firmware.
I commented in the lines:and compiled to get the firmware for my configuration.
I ran the PncConf to get a basic configuration that works... Except one error: When I try to run LinuxCNC it exits with an error.After using google I found out that the DPLL timer (that is necessary/recommended for Ethernet cards) must somehow be enabled in Code, But I've got no idea where and how to do that.
I also attached some files just in case. It would be great if someone could give me a hint on how to do that.
use work.i92_x9card.all;
use work.PIN_7I85S_7I78_34.all;
Last edit: 20 Apr 2022 10:57 by heinzischmirtzi. Reason: formating messed up
- Thank you received: 5946
20 Apr 2022 09:39 #240726
Replied by tommylight on topic Mesa 7i92M+7i85+7i78 'hm2_7i92.0.dpll.01.timer-us' not found
Moved to "driver boards"
20 Apr 2022 13:46 #240734
Replied by PCW on topic Mesa 7i92M+7i85+7i78 'hm2_7i92.0.dpll.01.timer-us' not found
You would need to edit the PIN_7I85S_7I78_34.vhd file and add the module ID
information for the DPLL. You can look at a pinout file with a D_34 at the end
as an example (say PIN_G540x2D_34.vhd) as these have the DPLL module
included.
included.
The following user(s) said Thank You: heinzischmirtzi
- heinzischmirtzi
10 Jun 2022 09:55 #244857
by heinzischmirtzi
Replied by heinzischmirtzi on topic Mesa 7i92M+7i85+7i78 'hm2_7i92.0.dpll.01.timer-us' not found
Thanks alot, it compiled round about one hour because its just below the limit, but it worked so far.
Time to create page: 0.124 seconds
