6i25 Error: BootSector is invalid
25 Apr 2022 17:11 #241221
by HansU
6i25 Error: BootSector is invalid was created by HansU
I inserted a new 6i25 and mesaflash gave me this:
That was the first point that confused me because I bought the 6i25 in a bundle together with a 7i85s and everyone says that a firmware should be installed.
Trying to flash gives me this:
Then I tried thisbut nothing happens after this.
I also tried with.. the same result
The LEDs on the card are always off.
Any idea what could be wrong?
$ sudo mesaflash --device 5i25 --readhmid
ERROR: no HOSTMOT2 firmware found. FFFFFFFF
Configuration Name:
BoardName :
FPGA Size: 0 KGates
FPGA Pins: 0
Number of IO Ports: 0
Width of one I/O port: 0
Clock Low frequency: 0.0000 MHz
Clock High frequency: 0.0000 MHz
IDROM Type: 0
Instance Stride 0: 0
Instance Stride 1: 0
Register Stride 0: 0
Register Stride 1: 0
Modules in configuration:
Configuration pin-out:
sudo mesaflash --device 5i25 --fallback --write 5i25_7i85sx2.bit
Checking file... OK
File type: BIT file
Then I tried this
$ sudo mesaflash --device 5i25 --fix-boot-block --write 5i25_7i85sx2.bit
Checking file... OK
File type: BIT file
Erasing sector 0 for boot block
I also tried with
$ sudo mesaflash --device 5i25 --fix-boot-block --fallback --write 5i25_fallback.bit
25 Apr 2022 17:34 #241224
Replied by PCW on topic 6i25 Error: BootSector is invalid
Do you have the latest Mesaflash?
github.com/LinuxCNC/mesaflash
(build instructions at bottom of page)
The following user(s) said Thank You: HansU
25 Apr 2022 17:38 #241225
by HansU
Replied by HansU on topic 6i25 Error: BootSector is invalid
25 Apr 2022 17:43 #241227
by HansU
Time to create page: 0.136 seconds
