need hardware recommendations full sheet plywood router
01 May 2022 01:33 - 01 May 2022 02:15 #241759
by tater1337
need hardware recommendations full sheet plywood router was created by tater1337
I see the maker made maslow cnc and a bit of critical reviews for it
I wonder why no one makes a cnc router like a panel saw
so I guess I'll look at making one
so 2,75 axis, with a cuttign head the weight of a full size wood router and a counterbalance along a 5ft rail
that gantry riding on a 9 foot rail (top an bottom rails) all chain driven by servos. any suggestions for servo sizes and the easiest driver board to use?
Last edit: 01 May 2022 02:15 by tater1337.
- robertspark
- Thank you received: 216
01 May 2022 05:47 #241770
by robertspark
Replied by robertspark on topic need hardware recommendations full sheet plywood router
the problem is weight.
the marslow they talk about back driving
forums.maslowcnc.com/t/building-a-maslow...h-stepper-motors/168
the way they overcome this on the marslow is having a very highly geared motor.
289.77:1 reduction gearbox and a 7ppr encoder
I cannot seem to find the power (voltage and current) rating of the marslow motor
maslowcommunitygarden.org/Maslow-CNC-Motor.html
if you find that info then you can approximate it for whatever drive ratio
- robertspark
01 May 2022 19:39 - 01 May 2022 19:48 #241809
by robertspark
github.com/MaslowCNC/Electronics/blob/ma...5)%20Model%20(1).pdf
can't identify the h bridge chip but it seems to be running off 12v
.... L298!!
www.st.com/content/ccc/resource/technica...ns/en.CD00000240.pdf
.... L298!!
Last edit: 01 May 2022 19:48 by robertspark.
- Thank you received: 5943
01 May 2022 20:45 #241813
They are cheap, have no current limiting as they require L297 for limiting and step/dir capabilities, can be used directly wire to parallel port as LinuxCNC can output quadrature 4 pin signals for it.
For nearly the same price there are much better drivers, those small 3D printer ones, they have step/dir and current limiting included.
Replied by tommylight on topic need hardware recommendations full sheet plywood router
Sure looks like it as it does need the diodes on all outputs.
.... L298!!
- robertspark
01 May 2022 21:19 - 01 May 2022 21:22 #241816
by robertspark
I liked the idea of the Maslow, but the math made my head ache.
I also wasn't too keen on strapping my 2.5kw router to a board held down by a few bricks..... controlled by am Arduino....
I am sure that linuxcnc would do a much better job with one of the non trivial kinematics as it's essentially a bipod
linuxcnc.org/docs/devel/html/motion/kine...n_trivial_kinematics
kind of like the drawer slide CNC.... sure it works but really!
Last edit: 01 May 2022 21:22 by robertspark.
05 May 2022 17:00 #242052
by tater1337
Replied by tater1337 on topic need hardware recommendations full sheet plywood router
all good comments.
I thought I clarified, but I guess I didn't.
I like the low footprint space of the Maslow, I do NOT like the chains and pendulum layout, and want one with a more conventional gantry
yes, I know I'd need counterweights then
I was thinking more like this, but instead of a wood gantry, just a steel pipe one like on a MPCNC
buildyourcnc.com/tutorials/example-cnc-machine-greenLean
- robertspark
05 May 2022 17:13 #242054
by robertspark
I know I've seen a few different vertical plasma table designs, but they have no cutting forces, so the forces relative to cut direction would be the same and relatively easy (the same) to compensate for.
I am aware that that specific manufacturer did not I believe have a good reputation although I suspect it was to do with support and not that the table did not work in principle.
Sorry I've never seen one in the flesh, keen to see any progress you make
05 May 2022 22:36 #242077
by tater1337
shhh, the plasma cutter is the project after this project, which is really after the other wood router project I posted elsewhere
06 May 2022 11:53 #242124
Replied by andypugh on topic need hardware recommendations full sheet plywood router
I see no reason that a vertical router wouldn't work. Especially one with a vacuum bed.
Or how about a very strong vacuum bed and use the ceiling as the spoilboard
06 May 2022 16:59 #242155
by Clive S
Replied by Clive S on topic need hardware recommendations full sheet plywood router
A bit like this:-
The following user(s) said Thank You: robertspark
Time to create page: 0.158 seconds
