Expanding 7i97 Smart Serial Ports using SP491 chip
- ContinenteCNC
- Thank you received: 3
04 May 2022 12:00 - 04 May 2022 12:02 #241975
by ContinenteCNC
Expanding 7i97 Smart Serial Ports using SP491 chip was created by ContinenteCNC
My current setup is 1x 7i97 + 2x 7i84. However, as 7i97 has only one RS-422 port available, I was able to wire only one of the 7i84 boards.
The ideal approach would be to employ, for example, a 7i44 to expand 7i97 smart serial ports. But I’m in a tight schedule and nowhere near the US or Europe to easily find a mesa supplier.
I might be able to get a 7i47s (waiting for the seller to check if he still has the board). Would it work to expand 7i97 smart serial ports? If so, how to wire its 50 pin connector to 7i97 J1 (26 pin connector)? Will it be recognized automatically? Will it require firmware change?
If it doesn’t work I’ll need to move to an alternative way to wire up my second 7i84 with what a can find in my town.
I’ve just read some post from PCW saying it is possible to expand Smart Serial Ports using simply SP491 chip, but it is not clear for me how to do the wiring. Is to possible to wire the chip directly to P1 pins (IO34 to IO41)? Will it be recognized automatically? Will it require firmware change?
Thanks in advance, folks.
Bruno
Bruno
Last edit: 04 May 2022 12:02 by ContinenteCNC.
04 May 2022 15:22 #241983
Replied by andypugh on topic Expanding 7i97 Smart Serial Ports using SP491 chip
You might need a firmware change. Which firmware do you currently have?
I have attached the VHD files that define the pinout for the 4 normal firmwares.
The _7i78D firmware has smart-serial pins on expansion port pins 8/9/10 (TX/En/RX)
_7i76D has two sserial ports, on 7/8 and 9/10 (RX/RXX?RX ... no En?)
_7i74 has a full header of Smart-Serial (so is probably your best bet if you want to reflash firmware)
The _51 firmware has nothing on the expansion port (GPIO only) so is likely to be no good for you.
04 May 2022 15:24 #241984
Oh, the link for the firmware and source code is www.mesanet.com/software/parallel/7i97.zip
- ContinenteCNC
05 May 2022 01:39 - 05 May 2022 02:01 #242017
by ContinenteCNC
Replied by ContinenteCNC on topic Expanding 7i97 Smart Serial Ports using SP491 chip
Hi, Andy!
Thanks for your quick answer!
I’ve just downloaded the files!
This is one of my first times working with mesa cards. I have very little experience with them. I was able to setup 1x 7i97 + 1x 7i84, but I’m yet to learn these more advanced topics, like firmware change.
Please, correct me if I’m wrong, but to check the current firmware in my 7i97 I have o issue the following command:
mesaflash --device 7I97 --addr 10.10.10.10 –readhmid
I’ll check it tomorrow when I get to the machine and comeback with the answer.
Regarding the _7i74 firmware, what do you mean by “full header of Smart-Serial”?
My last doubt is regarding the card<=>chip wiring. SP491 has 14 terminals:
1 NC No connect
2 R Receiver output
3 REB Receiver output enable active LOW
4 DE Driver output enable active HIGH
5 D Driver input
6 GND Ground connection
7 GND Ground connection
8 NC No connect
9 Y Non-inverting driver output
10 Z Inverting driver output
11 B Inverting receiver input
12 A Non-Inverting receiver input
13 NC No connect
14 VCC Positive supply
What would be a typical application circuit? (wiring betwen SP491 and 7i84's J1 connector)
SP491 / 7i84 (J1)
Z=>RXA
Y=>RXB
A<=TXA
B<=TXB
SP491 / 7i97 (P1)
D<=TX
R=>RX
REB/ DE<=EN
Am I close?
Will it require terminating resistors something besides power?
Thanks in advance!
Bruno
1 NC No connect
2 R Receiver output
5 D Driver input
8 NC No connect
13 NC No connect
SP491 / 7i84 (J1)
Z=>RXA
Y=>RXB
A<=TXA
B<=TXB
SP491 / 7i97 (P1)
D<=TX
R=>RX
REB/ DE<=EN
Am I close?
Thanks in advance!
Bruno
Last edit: 05 May 2022 02:01 by ContinenteCNC.
05 May 2022 09:48 #242027
I mean that almost every pin on the expansion header belongs to a smart-serial channel (8 of them).
The other firmwares have, at most, two smart-serial channels on the expansion header.
Sorry, I can't really help on the chip pin assignments.
- ContinenteCNC
05 May 2022 13:58 #242040
by ContinenteCNC
The result from mesaflash --device 7I97 --addr 10.10.10.10 --readhmid
Configuration Name: HOSTMOT2
BoardName : MESA7I97
FPGA Size: 9 KGates
FPGA Pins: 144
Number of IO Ports: 3
Width of one I/O port: 17
Clock Low frequency: 100.0000 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: DPLL
There are 1 of DPLL in configuration
Version: 0
Registers: 7
BaseAddress: 7000
ClockFrequency: 100.000 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
There are 3 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: MuxedQCount
There are 6 of MuxedQCount in configuration
Version: 4
Registers: 5
BaseAddress: 3600
Module: MuxedQCountSel
There are 1 of MuxedQCountSel in configuration
Version: 0
Registers: 0
BaseAddress: 0000
Module: SSerial
There are 1 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5B00
Instance Stride: 64 bytes
Module: PWM
There are 6 of PWM in configuration
Version: 0
Registers: 5
BaseAddress: 4100
ClockFrequency: 200.000 MHz
Module: SSR
There are 1 of SSR in configuration
Version: 0
Registers: 2
BaseAddress: 7D00
Module: InMux
There are 1 of InMux in configuration
Version: 0
Registers: 5
BaseAddress: 8000
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for TB1/TB2/TB3
Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir
1 0 IOPort PWM 0 PWM (Out)
14 1 IOPort PWM 1 PWM (Out)
2 2 IOPort PWM 2 PWM (Out)
15 3 IOPort PWM 3 PWM (Out)
3 4 IOPort PWM 4 PWM (Out)
16 5 IOPort PWM 4 /Enable (Out)
4 6 IOPort PWM 5 PWM (Out)
17 7 IOPort PWM 5 /Enable (Out)
5 8 IOPort PWM 0 /Enable (Out)
6 9 IOPort MuxedQCount 0 MuxQ-A (In)
7 10 IOPort MuxedQCount 0 MuxQ-B (In)
8 11 IOPort MuxedQCount 0 MuxQ-IDX (In)
9 12 IOPort MuxedQCount 1 MuxQ-A (In)
10 13 IOPort MuxedQCount 1 MuxQ-B (In)
11 14 IOPort MuxedQCount 1 MuxQ-IDX (In)
12 15 IOPort MuxedQCount 2 MuxQ-A (In)
13 16 IOPort MuxedQCount 2 MuxQ-B (In)
IO Connections for TB4/TB5
1 17 IOPort MuxedQCount 2 MuxQ-IDX (In)
14 18 IOPort MuxedQCountSel 0 MuxSel0 (Out)
2 19 IOPort SSR 0 Out-00 (Out)
15 20 IOPort SSR 0 Out-01 (Out)
3 21 IOPort SSR 0 Out-02 (Out)
16 22 IOPort SSR 0 Out-03 (Out)
4 23 IOPort SSR 0 Out-04 (Out)
17 24 IOPort SSR 0 Out-05 (Out)
5 25 IOPort SSR 0 AC Ref (Out)
6 26 IOPort InMux 0 Addr0 (Out)
7 27 IOPort InMux 0 Addr1 (Out)
8 28 IOPort InMux 0 Addr2 (Out)
9 29 IOPort InMux 0 Addr3 (Out)
10 30 IOPort InMux 0 Data0 (In)
11 31 IOPort SSerial 0 RXData0 (In)
12 32 IOPort SSerial 0 TXData0 (Out)
13 33 IOPort SSerial 0 TXEn0 (Out)
IO Connections for P1
1 34 IOPort None
14 35 IOPort None
2 36 IOPort None
15 37 IOPort None
3 38 IOPort None
16 39 IOPort None
4 40 IOPort None
17 41 IOPort None
5 42 IOPort None
6 43 IOPort None
7 44 IOPort None
8 45 IOPort None
9 46 IOPort None
10 47 IOPort None
11 48 IOPort None
12 49 IOPort None
13 50 IOPort None
This is probably the standard firmware, isn't it?
There P1 connector is indeed empty.
I'm going to load the firmware you've recommended me.
Just to make sure it will work for me, the _7i74 firmware will only add connections to P1, the remaining pins will remain just the same, won't it?
FPGA Size: 9 KGates
FPGA Pins: 144
IDROM Type: 3
Module: DPLL
Version: 0
Registers: 7
BaseAddress: 7000
Module: WatchDog
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
Version: 0
Registers: 5
BaseAddress: 1000
Module: MuxedQCount
Version: 4
Registers: 5
BaseAddress: 3600
Version: 0
Registers: 0
BaseAddress: 0000
Module: SSerial
Version: 0
Registers: 6
BaseAddress: 5B00
Module: PWM
Version: 0
Registers: 5
BaseAddress: 4100
Module: SSR
Version: 0
Registers: 2
BaseAddress: 7D00
Module: InMux
Version: 0
Registers: 5
BaseAddress: 8000
Module: LED
Version: 0
Registers: 1
BaseAddress: 0200
1 34 IOPort None
14 35 IOPort None
2 36 IOPort None
15 37 IOPort None
3 38 IOPort None
16 39 IOPort None
4 40 IOPort None
17 41 IOPort None
5 42 IOPort None
6 43 IOPort None
7 44 IOPort None
8 45 IOPort None
9 46 IOPort None
10 47 IOPort None
11 48 IOPort None
12 49 IOPort None
13 50 IOPort None
05 May 2022 14:37 #242042
Yes. Any 7i97 firmware will leave the 7i97 part of the system configured the same.Just to make sure it will work for me, the _7i74 firmware will only add connections to P1, the remaining pins will remain just the same, won't it?
- ContinenteCNC
05 May 2022 15:54 #242046
by ContinenteCNC
Thanks, Andy!!
I will flash the firmware and then come back with the outcome.
By the way, is the _51 firmware the generic one?
Just in case I have to flash it back to standard.
Does LinuxCNC 2.8 (from live CD) have full support to 7i97 firmware? I mean, I am not supposed to have any problem related to version as I try to flash the new firmware?
Anyway, I'll read a little more about firmware flashing and give it a try.
Thanks!
Bruno
Thanks!
Bruno
05 May 2022 16:44 #242049
The 2.8 config tools might not know how to configure for the 7i97, but the system itself does not care about the firmware, the driver is very flexible that way.
- ContinenteCNC
05 May 2022 16:57 #242050
by ContinenteCNC
You mean the Pnconf Wizard?
If so, I'm writing my own hal/ini files from basic7i97.
But mesaflash will work just fine to flash firmware, won't it? No need to upgrade to 2.9 to flash it?
