7i76e Analog spindle control question
05 May 2022 19:24 #242061
by hoverdj
7i76e Analog spindle control question was created by hoverdj
I'm trying to use the analog spindle control on the 7i76e to control a speed controller that uses a potentiometer on a floating ground at line voltage. I'm using a KBSI-250D signal isolator to protect things and bring the signal from the 7i76e to the proper levels. I have configured the spindle output to 5v at full speed (as required by the controller).
Current wiring configuration:
Ground from an unused step/dir to TB4 pin 1
5v from same unused step/dir to TB4 pin 3
TB4 pin 2 to KBSI input +
Ground from unused step/dir to KBSI input -
Problem is, I only get 2.44v at full speed rather than the full 5v I would expect. Interestingly, measuring TB4 pin 2 and pin 3, I get 2.55v (making up the rest of the 5v I was expecting).
I'm sure I'm missing something obvious, but I sure cant see what it is.
HAL and INI files attached.
Any ideas?
Darryl
Any ideas?
Darryl
05 May 2022 19:32 - 05 May 2022 19:48 #242063
Replied by PCW on topic 7i76e Analog spindle control question
You have (in the spindle section of the .ini file):
OUTPUT_SCALE = 21000
and
OUTPUT_MAX_LIMIT = 10500
This means you can only ever get to 1/2 full scale (10500/21000)
and
Last edit: 05 May 2022 19:48 by PCW.
06 May 2022 14:37 #242143
by hoverdj
Replied by hoverdj on topic 7i76e Analog spindle control question
Brilliant! Thank you!
Darryl
Darryl
Time to create page: 0.107 seconds
