Mesa 7i96
01 Jun 2022 14:00 #244372
by rohit269
Sir,
I am facing problem, when network failure or power cut linuxcnc indicating error. Than starting linuxcnc software again, but linuxcnc show the beginning window this reason my work peace, not completed so this very difficult to start work the at same point. So please tell how to solve this problem.
- smc.collins
- Thank you received: 109
03 Jun 2022 10:53 - 03 Jun 2022 10:54 #244501
by smc.collins
Replied by smc.collins on topic Mesa 7i96
I am subscribing to this. My advice, and you can take it as you will. Try to break your maching programs into as many manageably sidezed sub operations as you can, and lay them out in a way and in a order that makes restarting easier.
create a grid
roughing 1 area1, area 2 etc
Pockets , pocket 1, pocket 2 etc.
this way you can compare the CAM or other G code to the physical part and restart from the failed operation. but journaling of last op position as a logged value and having it kept as a way to restart from tool failure etc, that would be really handy.
create a grid
Last edit: 03 Jun 2022 10:54 by smc.collins.
- Thank you received: 5946
03 Jun 2022 12:12 #244515
Replied by tommylight on topic Mesa 7i96
In your ini file TRAJ section add this:That saves the last position of the machine so when you restart have a look at the DRO and write down the values, then home and move back to those values, then click on the preview on the part from where to continue and use the "run from here".
[TRAJ]
POSITION_FILE = position.txt
The following user(s) said Thank You: rohit269, smc.collins
Time to create page: 0.149 seconds
