MESA 5i26+7i76 Startup issue
24 Aug 2022 08:40 #250308
by Alveolis
MESA 5i26+7i76 Startup issue was created by Alveolis
my CNC setup is quite finished and runs fine,
however, I have an recurring issue at startup,
where it takes several attempts to get the motor running at the proper speed , homing is often tricky ...
But every thing works ok if jogged manually. The problem disappears after a successful homing cycle.
What could be the source of this erratic behavior ?
Could this just be a tired PSU, or a deeper problem with my configuration ?
If someone recognize those symptoms, I would welcome any hint...
thx
thx
- Thank you received: 5983
24 Aug 2022 10:24 #250312
Replied by tommylight on topic MESA 5i26+7i76 Startup issue
Try to jog all 3 axis at the same time, if they stop while holding the jog buttons, change the power supply or lower the motor current on the drives.
Time to create page: 0.145 seconds
