Is my 7i76e about to expire?
- charleyann
- Thank you received: 10
29 Aug 2022 14:35 #250686
by charleyann
Is my 7i76e about to expire? was created by charleyann
I've been getting read errors more and more often.
Lately the hm2_7i76e.0.read.tmax has been hitting 15,000,000.
The machine will be running commands or just sitting there and hm2_7i76e.0.read.tmax will be around 400,000
and then bam it jumps up and errors out.
I have tried 3 different computers all with good latency numbers around 25,000ns.
All with Debian bullseye. Mate, xfce and LxQt have all been used with QtDragon and Probe Basic.
The machine has been operational for almost 2 years without any issues like this.
The errors started early this summer and have been getting more frequent.
I thought it might be heat related but it happened this morning right after a cold start.
I've read through many threads about trouble shooting this, nothing has had any effect. I'm thinking it's the 7i76e.
Any thoughts?
Any thoughts?
29 Aug 2022 15:00 #250687
Replied by PCW on topic Is my 7i76e about to expire?
If you get a read error, does the /INIT LED light on the 7I76E?
What are the ping times?
(run for a minute or so while stressing the PC)
29 Aug 2022 16:37 #250695
by arvidb
Replied by arvidb on topic Is my 7i76e about to expire?
A long shot, but have you tried a different cable?
I know any Ethernet cable should work, but while fooling around running 'ping -i 0.002 <Mesa-7i96S-ip>' using an old CAT5E cable (3 m long) I got a noticeable amount of lost packets. After changing to a new CAT6 cable I got none. Not sure how significant it is (or if it would even show up as large tmax times) - but yeah, maybe worth a try?
- charleyann
29 Aug 2022 16:43 #250697
by charleyann
Replied by charleyann on topic Is my 7i76e about to expire?
Ping times are good:
cncv1@cncv1-1:~$ ping 10.10.10.10
PING 10.10.10.10 (10.10.10.10) 56(84) bytes of data.
64 bytes from 10.10.10.10: icmp_seq=1 ttl=64 time=0.133 ms
64 bytes from 10.10.10.10: icmp_seq=2 ttl=64 time=0.071 ms
64 bytes from 10.10.10.10: icmp_seq=3 ttl=64 time=0.069 ms
64 bytes from 10.10.10.10: icmp_seq=4 ttl=64 time=0.069 ms
64 bytes from 10.10.10.10: icmp_seq=5 ttl=64 time=0.071 ms
The INIT led has been on in the past.
This is so frustrating! I had half a dozen read errors in the first half hour this morning. Now its over two hours and I can't get it to fail.
This is what I have been seeing for the last couple of months. Many errors in a short time mixed with long run times with no errors!
Looking at tmax I can see its right on the edge:
cncv1@cncv1-1:~$ halcmd show param *.tmax
Parameters:
Owner Type Dir Value Name
42 s32 RW 85799 classicladder.0.refresh.tmax
71 s32 RW 47605 dbmist.tmax
68 s32 RW 68668 debounce.0.tmax
36 s32 RW 0 hm2_7i76e.0.read-request.tmax
36 s32 RW 2794658 hm2_7i76e.0.read.tmax
36 s32 RW 383016 hm2_7i76e.0.write.tmax
Generally anything over 3000000 will cause the error.
Parameters:
29 Aug 2022 17:10 #250701
If the /init light is on it suggests more of a host or al least
Ethernet communications issue.
Does dmesg show a link up/down transition?
The write tmax is quite bad also which points to a host issue
- Thank you received: 5983
29 Aug 2022 17:11 #250702
Replied by tommylight on topic Is my 7i76e about to expire?
First change the cable, i had the same issue as ArviDB with a 5M cable, it would loose connection at random.
Then pay attention at the other equipment in the shop, what is turned on when connection gets flaky?
- charleyann
29 Aug 2022 17:47 #250708
by charleyann
ok, more testing.
I have backups of two linuxcnc installations, one with debian 11 mate and the other with Debian 11 LxQt
Using Clonezilla I can switch back and forth in about 10 minutes.
Both installations use the same 5.10.0-17 rt kernel
With LxQt when I start up Probe basic I get the read error immediatly
Parameters:
42 s32 RW 36994 classicladder.0.refresh.tmax
71 s32 RW 29561 dbmist.tmax
68 s32 RW 16164 debounce.0.tmax
36 s32 RW 15480633 hm2_7i76e.0.read.tmax
36 s32 RW 77653 hm2_7i76e.0.write.tmax
With Mate I get the results I've described earlier.
Out of desperation I added everything I've tried in the past to boot parameters and now the mate installation seems stable (for how long I don't know)
I have tried all of these in the past but not all combined.
Grub as of now:
GRUB_CMDLINE_LINUX_DEFAULT="splash isolcpus=1 intel_idle.max_cstate=0 processor.max_cstate=0 acpi_irq_nobalance noirqbalance resume=UUID=5ec67429-5af1-4b03-9800-a8b2fc0ec9dd"
I have changed the cable in the past, but I'll try another one.
Interesting that there is so much difference between the two OS's wit the same kernel.
Parameters:
Grub as of now:
29 Aug 2022 18:37 #250717
Now i can add, check the PC power supply or try another one as checking it requires a scope.
Do you have another PC to test with?
No need to install anything, just yank the drive and put it in the other PC.
- charleyann
29 Aug 2022 18:48 #250720
by charleyann
Interesting, all of my testing has been with 3 motherboards but the same case and power supply.
I'll swap out the power supply and see what happens.
- charleyann
29 Aug 2022 20:25 #250729
by charleyann
Swapped out the power supply and it got worse hm2_7i76e.0.read.tmax went to 1505820
Tried another and I'm back to about what I had with the original. I only have the two extras to test with.
This is what I have now:
Parameters:
42 s32 RW 56029 classicladder.0.refresh.tmax
71 s32 RW 30192 dbmist.tmax
68 s32 RW 39133 debounce.0.tmax
36 s32 RW 499782 hm2_7i76e.0.read.tmax
36 s32 RW 127248 hm2_7i76e.0.write.tmax
77 s32 RW 48908 hold1and.tmax
80 s32 RW 30413 hold1or.tmax
77 s32 RW 37965 hold2and.tmax
80 s32 RW 17408 hold2or.tmax
71 s32 RW 17121 holdtgl.tmax
74 s32 RW 30097 holdtgln.tmax
86 s32 RW 44482 ilowpass.0.tmax
29 s32 RW 50874 motion-command-handler.tmax
29 s32 RW 90288 motion-controller.tmax
83 s32 RW 30428 mpgincr.tmax
39 s32 RW 44037 pid.a.do-pid-calcs.tmax
39 s32 RW 45234 pid.s.do-pid-calcs.tmax
39 s32 RW 46969 pid.x.do-pid-calcs.tmax
39 s32 RW 38577 pid.y.do-pid-calcs.tmax
39 s32 RW 43093 pid.z.do-pid-calcs.tmax
89 s32 RW 16823 probe-sel.tmax
30 s32 RW 683116 servo-thread.tmax
77 s32 RW 29899 start1and.tmax
77 s32 RW 29883 start2and.tmax
74 s32 RW 39159 tglmist.tmax
I also swapped out the cable, didn't see any change.
I'll leave it run the rest of the day and see what happens.
Parameters:
Time to create page: 0.218 seconds
