7i96S encoders for THCAD
07 Sep 2022 00:21 #251370
by Dhoerauf
7i96S encoders for THCAD was created by Dhoerauf
Good evening Linuxcnc,
I have a 7i76s with a working cnc plasma table. I have THCAD-10 for torch height control, works great. I would like to add THCAD-5 for OMIC hypersense. i dont see the encoder B option in pncconfig. Is this a viable option for this board? I flashed the 7i96s dpl firmware and can see other encoders but no options for me to use.
Thanks in advance.
Thanks in advance.
07 Sep 2022 00:48 #251372
by phillc54
Replied by phillc54 on topic 7i96S encoders for THCAD
This is an issue in PnCconf, I have pushed a fix to master branch.
07 Sep 2022 23:54 #251451
by Dhoerauf
Replied by Dhoerauf on topic 7i96S encoders for THCAD
this was a big oops on my part i have a 7i96s, never post after a long day at work . is this still the case. i am running 2.9 master. I will check in the am.
Thanks Again
Thanks Again
- Thank you received: 6006
08 Sep 2022 00:40 #251452
Replied by tommylight on topic 7i96S encoders for THCAD
Having two or more THCAD connected to Mesa 7i96S or 7i76E requires flashing the firmware using mesaflash.
The firmware for Plasma will have the letters"pl" in the firmware name together with the card name.
Warning:
Always use firmware made strictly for the card you are trying to flash, so only 7i96S firmware with letters pl in the name in this case.
Warning:
08 Sep 2022 00:42 #251453
Topic title changed to reflect the correct card model and relation to THCAD.
08 Sep 2022 01:24 #251456
by phillc54
No worries, I was assuming that you meant 7i96s.
08 Sep 2022 23:34 #251526
by Dhoerauf
I had a chance to connect everything up today and test. 7i96s DPL firmware, linuxcnc 2.9, QTplasmac. The OHMIC hypersense with THCAD-5 works great. I wish i had started using linuxcnc long before i started with GRBL. This is soooo much better in all ways. Also converting my OX-CNC to linuxcnc and that is working great.
Thanks for all the help.
The following user(s) said Thank You: phillc54, tommylight
Time to create page: 0.205 seconds
