Driver Board Advice
- gene_weber
- Topic Author
- Thank you received: 6
07 Sep 2022 18:27 - 07 Sep 2022 18:43 #251429
by gene_weber
Driver Board Advice was created by gene_weber
Hi, I'm converting a mill to CNC. 3 axis to start, hopefully add a fourth in the future. Also has a 0-10v spindle speed control. I want to use ClearPath SDSK servos which have Enable+, Enable-, (energize motor windings) Input A+, Input A-, (Direction) and Input B+, Input B- (Step) inputs. I would prefer to use a computer I have lying around and avoid purchasing a PC. Those include a Dell Inspiron 5558 laptop, and an older than dirt HP Pavilion a4316f tower. I see that laptops aren't recommended due to latency issues. Is that still the case if an ethernet card like a 7i96s is used? Is the ancient tower PC with a PCI card actually a more robust option? The selection of Mesa PCI cards is confusing, although it may be a mute point since most are out of stock anyway. Are there other well supported driver cards? Thanks for your help.
Last edit: 07 Sep 2022 18:43 by gene_weber.
- Thank you received: 5983
07 Sep 2022 19:37 #251431
Replied by tommylight on topic Driver Board Advice
Most probably you can find Mesa 7i96S, others are hit-and-miss.
Not sure if it has 0-10V, although i have one driving a plasma cutter, so i do not need the 0-10V part.
Time to create page: 0.107 seconds
