MESA 7i95 Board Setup
02 Jan 2023 02:46 - 02 Jan 2023 02:48 #260748
Replied by PCW on topic MESA 7i95 Board Setup
I don't see any serious errors in the log.
Most common reasons I have seen for no motion in step/dir systems are:
1. Wiring errors
2. Step lengths too short
3. Drives disabled by wiring the "Drive Enable" pins (these are actually "Drive Disable" pins
Note: You would get a following error if you move/jog and there is no communication
1. Wiring errors
Last edit: 02 Jan 2023 02:48 by PCW.
02 Jan 2023 02:56 #260749
by TDudley
Replied by TDudley on topic MESA 7i95 Board Setup
This was my issue. I can now jog the X Axis.
Holy Cow!!! this has taken days/weeks to see a motor spin.
Thanks for getting me over the first hurtle. Now I need to get things tuned correctly.
I'm sure there will be more brick walls to bang my head against though.
I'll post a video on my YT channel soon now that I have something actually moving. Maybe others can benefit from my headaches.
06 Dec 2023 14:10 #287353
by slowpoke
Replied by slowpoke on topic MESA 7i95 Board Setup
I'm about to order a MESA board for CNC conversion of a 4 axis knee mill.
I'm leaning towards the 7i95t.
Is there any reason not to order and use this board?
I did a CNC conversion in the past using Mach, this will be first time with Linux. I'm very comfortable with electronics but have next to zero experience with Linux and have zero experience with LinuxCNC
- Thank you received: 6006
06 Dec 2023 16:36 #287367
Otherwise it is magnificent, i have one installed in a huge plasma machine in use daily for exactly 1.1 year, went there today it was in use, it is never powered off.
No issues, ever.
Replied by tommylight on topic MESA 7i95 Board Setup
Hard to find in stock.I'm leaning towards the 7i95t.
No issues, ever.
The following user(s) said Thank You: slowpoke
Time to create page: 0.168 seconds
