Component choice - given availability.
12 Dec 2023 23:46 #287988
by null
Component choice - given availability. was created by null
Hi All.
Can anyone suggest available(in stock) hardware options to drive a 3 axis mill equipped with:
Stepper Motors. Nema23 FL57STH56-3008B.
Stepper motor drivers.
Motor Power Supply: 18-50v DC.
Current: 4.2A (Peak) Max.
Current control: PWM.
Control inputs: 5V logic from current sinking (NPN) interface, 15mA typical.
Microstep: 128 (25600 steps/rev.)Max. 15 settings selected by dipswitch.
Max Pulse Rate: 300kHz.
Insulation Resistance: >500 mega ohm (@ 20deg C).
Dielectric strength: 500V AC for 1 minute.
Cooling: Heat Sink.
Ideally suggestions would include capacity for (in future) an additional axis, rigid tapping and positional feedback.
Mesa seems to be a popular option but I am not sure if any of their available products would work with my setup?
I assume a fairly basic PC would be adequate with a Mesa type device?
Thanks All - null.
Cooling: Heat Sink.
Thanks All - null.
- Thank you received: 5983
13 Dec 2023 00:04 #287989
Replied by tommylight on topic Component choice - given availability.
Mesa 7i96S
store.mesanet.com/index.php?route=produc...69_62&product_id=374
And yes, it has more than you need, it is available, it can be expanded a lot, and has also full spindle support/control.
The following user(s) said Thank You: null
