mesaflash does not detect 7i92TF
23 Dec 2023 18:00 #288934
Replied by PCW on topic mesaflash does not detect 7i92TF
There are no PWMgens in standard 7I76 firmware
(the Spindle Analog is done via sserial I/O)
The following user(s) said Thank You: angelnu
23 Dec 2023 21:15 #288947
by angelnu
Replied by angelnu on topic mesaflash does not detect 7i92TF
It is not for a spindle, it would be for a laser. As I did not use the 5 axis, I believed that the 5 axis could be used as PWM, with the 5i25 it seems that an axis like PWM could be used.
I did not use the PWM (the 5i25 card was broken) but in Halsow 4 axes of steps and a PWM were seen.
The idea is to be able to remove the spindle and put the laser on the same machine, would create a different machine in Linuxcnc.
23 Dec 2023 21:24 #288948
You would need to use firmware that has a PWMgen for that application.
I don't think there is currently firmware for the 7I92T +7I76 that matches the
5I25 firmware with one PWMgen on the last stepgen, but I can build it.
I can have this done sometime later today or tomorrow.
24 Dec 2023 01:15 #288960
7I92T firmware for one 7I76 with the last stepgen replaced with a PWMGen:
24 Dec 2023 05:26 #288970
by angelnu
Thank you very much, it was not necessary so fast, this is a hobby.
I wish you a Merry Christmas.
24 Dec 2023 14:15 #289001
Actually maybe a bit too fast... I think the last file has an error, so use this one instead:
Time to create page: 0.075 seconds
