Mesact not seeing mesaflash
- tcoleman978
17 Dec 2023 04:53 #288375
by tcoleman978
Mesact not seeing mesaflash was created by tcoleman978
I'm working with an RPI4B / 7i96s * bookworm, LinuxCNC is in and runs. I have installed Mesact and mesaflash per instructions (I think, I am a Linux dummy) can find them and run them. BUT mesact doesn't register that mesaflash is installed. What have I screwed up? I don't know where to look to even start.
Thank you
Thank you
- Thank you received: 5961
17 Dec 2023 13:17 #288401
Replied by tommylight on topic Mesact not seeing mesaflash
Just a stab in the dark:
sudo apt install mesaflash
then try again.
then try again.
- tcoleman978
17 Dec 2023 15:33 #288414
by tcoleman978
Replied by tcoleman978 on topic Mesact not seeing mesaflash
well...... hell.......3rd times a charm. Can I install it wrong but sill install it?
It works now so I guess that makes it a Linux question.
Thank you very much
Thank you very much
17 Dec 2023 15:41 #288418
Yes you can install it wrong, but you can also install it correctly and still not work, Linux has many versions and those versions have different opinions on where stuff should be, sometimes making hyperlinks that lead nowhere.
Compiling it with "make" will work only from that folder, compiling it with "make && make install" will also make hyperlinks and usually works from anywhere. I said usually.
Time to create page: 0.477 seconds
