IDROM IOPorts is 2 but MD IOPort NumInstances is 3, inconsistent
18 Dec 2023 02:20 #288451
by cornholio
I have some firmware I'm writing for a RV901T, spartan 6 based,
same card I was playing with for a SSREMOTE.
Setup has 2 ports with a 19 pins per port, modified mesaflash to recognise my board and all is good with the world.
The only issue I have is when loading the driver, based on the 7i90 EPP driver, I've had success modifying this driver to work with a 7c81 via EPP. The firmware I created was just 38 gpio pins. I saw some threads regarding the 7i93 & 7i98, but that didn't really help my situation. Any help would be great.
I'll include a dump of --readhmid via mesaflash.
18 Dec 2023 02:28 #288453
Replied by PCW on topic IDROM IOPorts is 2 but MD IOPort NumInstances is 3, inconsistent
The number of I/O ports in your pinout file does not match the number in your xxxcard file
18 Dec 2023 02:44 #288454
by cornholio
Replied by cornholio on topic IDROM IOPorts is 2 but MD IOPort NumInstances is 3, inconsistent
Card file seems ok, the guts
Pin file has 32 Module_ID entries.
I have 38 pins defined followed by 106 empty pin entries.
Mesa flash seems to detect everything and has no probs writing to flash.
package r01e_x16card is
-- r01e_x16 card specific info
constant ClockHigh: integer := ClockHigh90;
constant ClockMed: integer := ClockMed90;
constant ClockLow: integer := ClockLow90;
constant BoardNameLow : std_Logic_Vector(31 downto 0) := BoardNameMESA;
constant BoardNameHigh : std_Logic_Vector(31 downto 0) := BoardName9R01E;
constant FPGASize: integer := 16;
constant FPGAPins: integer := 256;
constant IOPorts: integer := 2;
constant IOWidth: integer := 38;
constant PortWidth: integer := 19;
constant LIOWidth: integer := 0; -- just txen on rev c cards
constant LEDCount: integer := 2;
constant SepClocks: boolean := true;
constant OneWS: boolean := false;
end package r01e_x16card;
18 Dec 2023 02:47 - 18 Dec 2023 02:47 #288455
Does your pinout file specify 2 I/O ports?
Last edit: 18 Dec 2023 02:47 by PCW.
18 Dec 2023 03:03 #288457
by cornholio
That would be the on the IOPortTag line the value after ClockLowTag ? Which is NumInstances of the ModuleRecord ?
Sorry for such a glaring mistake.
18 Dec 2023 03:28 #288458
(IOPortTag, x"00", ClockLowTag, x"02", PortAddr&PadT, IOPortNumRegs, x"00", IOPortMPBitMask),
The following user(s) said Thank You: cornholio
Time to create page: 0.153 seconds
