Galil DMC-17x0
24 Dec 2023 03:57 #288962
Replied by rodw on topic Galil DMC-17x0
So you turf the controller, and save just the motors and drivers if possible and connect it all up with linuxcnc and probably a mesa card. That will give you 9 axes.
- JamesHoward
24 Dec 2023 04:17 #288963
by JamesHoward
Replied by JamesHoward on topic Galil DMC-17x0
this makes no sense to me.... why would i turf a perfectly working controller?
like i had said emc supported this card....
24 Dec 2023 04:30 #288966
Linux is not the same as linuxcnc which is a motion controller application which runs on Linux. (Like mach3 runs on Windows).
Its possible in the very early days Galil might have supported EMC because Mach and EMC shared the same government developed motion controller when it was given to industry. But certainly if Galil can't produce a driver, I'm sorry but you are on the wrong forum.
- JamesHoward
24 Dec 2023 04:35 #288967
by JamesHoward
galil does produce a driver.....
24 Dec 2023 08:29 - 24 Dec 2023 08:35 #288973
If you want to keep the Galil controller then you don't need or even want LinuxCNC.
[edit]
Maybe Galil could tell you more.
Replied by Aciera on topic Galil DMC-17x0
As Rod already explained, they may have a driver for 'Linux', which is an operating system, but 'Linuxcnc' (formerly known as EMC(2)) is the application that turns the computer into a controller.galil does produce a driver.....
[edit]
Last edit: 24 Dec 2023 08:35 by Aciera.
- JamesHoward
24 Dec 2023 11:09 #288988
by JamesHoward
Even Mach basically bypasses the motion control part and just tells the galil where to go next... I understand the concept of motion controller controlling motion controller... Its messy! But in the cas of Mach, They made it work.... The issue I have with mach, is that it is only good for 4 axes! Moreover again EMC used to support Galil! Why does it not work now!?
24 Dec 2023 11:19 #288989
Is there any documentation for this?Moreover again EMC used to support Galil!
- JamesHoward
24 Dec 2023 12:27 - 24 Dec 2023 12:28 #288993
by JamesHoward
well, really, if i could find that i probably wouldnt be here... it is just something that i remember....
Last edit: 24 Dec 2023 12:28 by JamesHoward.
- JamesHoward
24 Dec 2023 12:31 #288994
by JamesHoward
I can see that i am just burning my wheels with nowhere to go....
Can anyone reccommend me an open source way to interpret g-code and have a gui for the galil?
Time to create page: 0.177 seconds
