MESA 7i97T, unable to ping board, strange lamp behavior
- flyingbrick
- Thank you received: 11
26 Dec 2023 09:13 - 26 Dec 2023 09:15 #289074
by flyingbrick
Hi all.
My card arrived today :-D
This took me some time to figure out what was going on and some time to figure out (well, 99.99% sure) that its not the controlling PC, but is the board itself.
PS, thats my dog snoring in the background, not me breathing, haha
- I have setup as per tutorial by Tommylight at www.forum.linuxcnc.org/27-driver-boards/...ethernet-mesa-boards (Thanks!)
- I have confirmed that I can connect my PC by ethernet cable to my homes network and ping other devices
- i have tried using both the default jumper settings of DOWN DOWN to select 192.168.1.121 as well as DOWN UP to select 10.10.10.10 addresses, all fail to return a ping.
- The board flashes as per this video when it is connected to my home network or direct to my control PC
- without connection to another device or network, only the yellow power lamp is illuminated.
I hope someone can give me some tips I have not tried mesaflash or anything like that yet- but it seems pointless if I cannot even get it to ping back to me.
I hope someone can fire some wisdom my way :-D
Last edit: 26 Dec 2023 09:15 by flyingbrick.
- Thank you received: 5934
26 Dec 2023 09:25 #289076
Replied by tommylight on topic MESA 7i97T, unable to ping board, strange lamp behavior
1. what does "ip a" return?
2. Get a proper 5V power supply, that looks like the board is resetting due to lack of power.
The following user(s) said Thank You: flyingbrick
- flyingbrick
26 Dec 2023 10:09 #289079
by flyingbrick
Replied by flyingbrick on topic MESA 7i97T, unable to ping board, strange lamp behavior
Hi Tommy.
frustrating that this could be such a simple error, but i think you are right.
I'm using a PC power supply to get it going on the bench - this should supply more than enough but looks like when i plug in the ethernet cable, voltage starts fluctuating *awkward*
ip a returns this.
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host noprefixroute
2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
link/ether d8:3a:dd:b6:f1:c7 brd ff:ff:ff:ff:ff:ff
inet 10.10.10.11/24 brd 10.10.10.255 scope global eth0
inet6 fe80::da3a:ddff:feb6:f1c7/64 scope link
3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether d8:3a:dd:b6:f1:c8 brd ff:ff:ff:ff:ff:ff
inet 192.168.5.92/24 brd 192.168.5.255 scope global dynamic noprefixroute wlan0
valid_lft 81294sec preferred_lft 81294sec
inet6 fe80::ff07:7508:ea6c:4112/64 scope link noprefixroute
ip a returns this.
26 Dec 2023 15:34 #289094
Replied by PCW on topic MESA 7i97T, unable to ping board, strange lamp behavior
Looks like an issue with the 5V power (resetting over and over)
I would use a decent 2A or so 5V power source and make sure the
power wires are not too thin or long.
- flyingbrick
28 Dec 2023 04:44 #289228
by flyingbrick
Thanks guys. Had multiple issues. Using a laboratory power supply the card boots up fine and after much stuffing around have got the raspberry pi able to ping it.
Thanks again to the great community and support here.
Time to create page: 0.101 seconds
