Board compatabilty configuraton guide
- Usolutions
14 Jan 2024 22:20 #290712
by Usolutions
Board compatabilty configuraton guide was created by Usolutions
Hi
I can not wrap my head around, which cards can be used with witch cards, as it does not really have clear how-to
I am trying to figure out a kit for for a 1992 Boley duo3030 dual spindle dual turret lathe. It has 8 analog simodrive servos, and bunch of auxilary systems.
Preferred PC connection is USB or Ethernet.
I am looking for stuff available for purchase right now.
Looking on EUSurplus, my current config is :
7i80HDT FPGA board
2x 7i33TA for 8 analog servo control
7i44 for non-motion critical IO distribution
7i71 for non-motion critical outputs
7i73 for control panel
7i70 for auxilary inputs like homing switches, turret position sensors, etc
Is my understanding, that this kit is copatable and interconnectable, correct?
7i80HDT FPGA board
15 Jan 2024 00:20 #290721
Replied by PCW on topic Board compatabilty configuraton guide
Yes, all those cards can work together. It will likely require quite a bit of
hand tweaking of hal/ini files
The following user(s) said Thank You: Usolutions
- Usolutions
15 Jan 2024 12:14 #290752
by Usolutions
Replied by Usolutions on topic Board compatabilty configuraton guide
at least editing files is free
Time to create page: 0.126 seconds
