RS485 module
27 Jan 2024 00:36 - 27 Jan 2024 11:47 #291704
by vre
RS485 module was created by vre
This rs485 module will work with linuxcnc in real time?
If for example drive it from mesa card rs485 port?
www.aliexpress.com/item/1005003367175020.html
This ali store www.aliexpress.com/store/2348129
has a lot of rs485 modules with many functions general i/o relays sensors etc
that if can work with linuxcnc in real time it will be perfect.
Last edit: 27 Jan 2024 11:47 by vre.
27 Jan 2024 01:32 #291705
Replied by PCW on topic RS485 module
Possibly...
The experimental mesa-modbus interface works
with similar relay modules. (I've had one clicking away on my desk
for a couple of months now) There _is_ still
work that needs to be done to improve mesa-modbus
27 Jan 2024 08:36 #291722
by roland
Replied by roland on topic RS485 module
Really real-time? Via Modbus 485?
27 Jan 2024 11:11 - 27 Jan 2024 11:46 #291741
by vre
Replied by vre on topic RS485 module
Except from mesa cards also there are some industrial mobos that have rs485 onboard ports or rs232 to rs485 adapter with these can work in real time?
Last edit: 27 Jan 2024 11:46 by vre.
27 Jan 2024 12:31 #291745
by roland
Real time is probably possible. But how do you define real time? I can't imagine that Modbus can work with a cycle time of 1 ms (Servo-Thread)
27 Jan 2024 17:38 - 27 Jan 2024 17:40 #291753
by vre
Real time has predefined latency bounds -> stable jitter.
These modules are not for motion but for general i/o so more than 1ms is no problem
Last edit: 27 Jan 2024 17:40 by vre.
The following user(s) said Thank You: roland
