7i76e to Durapulse connection
- gardenweazel
- Thank you received: 5
12 Mar 2024 19:19 #295773
by gardenweazel
Replied by gardenweazel on topic 7i76e to Durapulse connection
What I have yet to understand is that the pyvcp-panel.xml file uses a value of 3000. Why is that?
I would expect to see these INI values which I assume are RPM?
OUTPUT_MIN_LIMIT = 0.0
OUTPUT_MAX_LIMIT = 24000
- Thank you received: 5972
12 Mar 2024 19:27 #295775
Replied by tommylight on topic 7i76e to Durapulse connection
Change it to 24000, save and test.
The following user(s) said Thank You: gardenweazel
12 Mar 2024 19:28 #295776
Replied by PCW on topic 7i76e to Durapulse connection
Those are hardware settings, I would think pyvcp would use
the ini file spindle settings here:
linuxcnc.org/docs/2.9/html/config/ini-co...:ini:sec:spindle-num
3000 RPM is probably the default value if not specified. This does seem like
a pncconf bug to leave out the generic spindle ini settings
- gardenweazel
12 Mar 2024 20:13 #295782
by gardenweazel
Ok, I just added the green FORWARD stuff to my config.. Should I remove the red print?
[SPINDLE_0]
P = 0.0
I = 0.0
D = 0.0
FF0 = 1.0
FF1 = 0.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 24000
OUTPUT_SCALE = 24000
OUTPUT_MIN_LIMIT = 5000
MIN_FORWARD_VELOCITY = 5000
MAX_FORWARD_VELOCITY = 24000
INCREMENT = 200
[SPINDLE_0]
P = 0.0
I = 0.0
D = 0.0
FF0 = 1.0
FF1 = 0.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 24000
INCREMENT = 200
12 Mar 2024 20:16 #295783
No, those are hardware setup parameters and necessary.
- gardenweazel
13 Mar 2024 02:06 #295799
by gardenweazel
Ok, all I did was add those params as described above and everything words as described.
Here's what I did:
OUTPUT_MIN_LIMIT = 5000 <<-- I changed this from zero to 5000
OUTPUT_MAX_LIMIT = 24000 <<-- no change to this line
INCREMENT = 200
I added the latter 3 lines in green.
Thanks to those who responded with feedback!
Here's what I did:
INCREMENT = 200
13 Mar 2024 02:30 #295801
Did that solve the out of range spindle speed error?
- gardenweazel
13 Mar 2024 03:27 #295802
by gardenweazel
Yeah it did believe it or not.
I'd probably report that as a bug?
Too weird...
Too weird...
Time to create page: 0.116 seconds
