7I96 Encoder Spindle tuning
18 Feb 2024 20:14 #293707
by kbec
7I96 Encoder Spindle tuning was created by kbec
I have an optical encoder, with A+ B+ and Index that seems to be generating signals.
I also have a SPINX board attached that is driving a digital pot to my motor speed control.
The SPINX seems to control the speed, but my motor should go from 0 to 1200 RPMs,
What do I need to look at in the HAL watch to see what I need to possibly change? I know the encoder is not producing the right speed, nor is the SPINX driving to pot from 0-100%.
18 Feb 2024 20:34 #293710
Replied by PCW on topic 7I96 Encoder Spindle tuning
Can you post your hal/ini files?
18 Feb 2024 22:47 #293724
by kbec
Replied by kbec on topic 7I96 Encoder Spindle tuning
Here are all my hal and ini files
19 Feb 2024 00:32 #293730
So the basic setup looks OK:
PWM scale set to 1200 so you should get 0V
when the commanded spindle speed is 0,
and full scale (spinout=spin+) at a commanded
speed of 1200 RPM
Do you get these values?
The encoder scaling say 20 which would be correct for a
5 slot disk using quadrature (A and Is thsi what you have?
speed of 1200 RPM
19 Feb 2024 00:56 #293732
by kbec
19 Feb 2024 04:24 #293740
What RPM do you get if you connect your drive speed command signal to 5V?
Also a hand made encoder may have fairly dirty signals so it
might be worth looking at them with halscope and perhaps
setting the encoder up for slower signals and better filtering
20 Feb 2024 20:50 #293861
by kbec
I think the problem may be the board, I had to order some parts for it. It would explain what is happening I think. I'll update you when I fix the board and let you know. Thanks as always
24 Feb 2024 17:35 #294225
by kbec
I think the encoder is working, my issue is with the way my SPINX1 is wired. I think the pot should go from 0-7V, mine is peaking at about 2.5. I think this is because I have the SPINX1 ENA tied to my OUT0+ which is 5V. The instructions on the SPINX1 say to power the board is 5v pin 1 and 6.
How can I wire it so that I can get the digital pot to be from 0-7v? What does pin2 GND on the SPINX1 go to?
24 Feb 2024 17:44 #294226
The analog output voltage is not related to the 5V supply
It is the voltage difference between SP- and SP+ times
the PWM duty cycle, so for example if you had +12V
on SP+ and 0V on SP- and a 50% duty cycle PWM,
you would get 6V (12V* 50%) out.
The SPINX1A ENA pin must be _low_ for the analog out
to work. So for example if you wanted SSR5 to enable
the analog out, you would connect SSR5A to SPINX1 /ENA
and SSR5B to 5V GND
and SSR5B to 5V GND
24 Feb 2024 19:44 #294239
by kbec
I kind of get what you are saying, but I am lost.
I am not sure how to connect the SPINX1 to my 7i96 card, and if I have my voltage wrong feeding it somewhere.
In my hal file, I have:
loadrt hm2_eth board_ip="192.168.1.121" config="num_encoders=1 num_pwmgens=1 num_stepgens=4 sserial_port_0=0xxxxxxx"
setp [HMOT](CARD0).pwmgen.pwm_frequency 20000
setp [HMOT](CARD0).pwmgen.pdm_frequency 6000000
setp [HMOT](CARD0).watchdog.timeout_ns 5000000
do the pdm and pwm both need to be set, or is one overriding the other one?
I am sorry, but I forgot a lot of my electronics knowledge a long while ago.
Time to create page: 0.195 seconds
