7I96 Encoder Spindle tuning
24 Feb 2024 20:02 #294243
Replied by PCW on topic 7I96 Encoder Spindle tuning
First the connections must be correct:
7I96 TB2 pin 1 --> SPINX1A pin 1 (GND)
7I96 TB2 pin 3 --> SPINX1A pin 3 (PWM)
7I96 TB2 pin 5 --> SPINX1A pin 5 (DIR)
7I96 TB2 pin 6 --> SPINX1A pin 6 (5V)
7I96 TB3 pin 14 --> SPINX1A pin 4 (/ENA) SSR0+
7I96 TB3 pin 13 --> 5V GND (SSR0-)
24 Feb 2024 21:25 #294258
by kbec
Replied by kbec on topic 7I96 Encoder Spindle tuning
I did wire it like you described. At 100% I’m getting about 2.5v and 80rpm, at 50% I have 0v and about 10 rpms
24 Feb 2024 21:44 #294263
What is the voltage between SP+ and SP- ?
(measure at 0 % 50 % and 100%)
25 Feb 2024 02:18 #294318
by kbec
At 0(off) I have .058 disconnected and 2.62 connected to the motor control board
At 50% I have -.183 disconnected and 2.73 connected to the motor control board
At 100% I have -.210 disconnected and 2.51 connected to the motor control board
That is with my negative on sp- and positive lead on sp+
25 Feb 2024 03:13 #294321
So what that means is that the motor control board cannot supply
the few mA of current that the SPINx1A requires.
Does the motor control card have any specifications for the speed control input?
25 Feb 2024 17:03 #294404
by kbec
I came across another similar post where he used another controller board. I have ordered one and hopefully that will fix the issue.
Thanks for your help
25 Feb 2024 17:26 #294410
I could also possibly be done with an external (and well isolated) 10V supply
02 Mar 2024 18:59 #294930
by kbec
How would I connect that? The manual for the board says it is supplied with a 5K potentiometer.
02 Mar 2024 19:58 #294937
Can you post a link to the manual here?
03 Mar 2024 04:12 #294974
by kbec
I have the 240-DS if it matters, The motor runs fine when attached to the potentiometer that came with it.
