7i87 + 7i96s + THCAD2 compatibility?
22 Feb 2024 17:02 #293996
by santy
7i87 + 7i96s + THCAD2 compatibility? was created by santy
Hello.
I need an analog input card for my current project.
Can i use the 7i87 with a 7i96s? What interface would i require to use both cards simultaneously?
I use regular mini PCs with 1 ethernet port
Thank you.
Thank you.
22 Feb 2024 18:29 #294009
Replied by PCW on topic 7i87 + 7i96s + THCAD2 compatibility?
Yes, you can use any sserial interface card directly with a 7I96S
(The 7I96S has one sserial expansion port)
No additional hardware is needed (other than the
connecting cable)
connecting cable)
22 Feb 2024 22:27 #294025
by santy
Replied by santy on topic 7i87 + 7i96s + THCAD2 compatibility?
Thank you. Could you point to this cable please?
22 Feb 2024 23:03 #294027
Replied by rodw on topic 7i87 + 7i96s + THCAD2 compatibility?
Its simply a modified ethernet cable as described in the Mesa instructions. Tajjke care that you understand the difference in cable wiring standardsThank you. Could you point to this cable please?
Time to create page: 0.098 seconds
