7i95 T for pwm 6 axis
25 Feb 2024 13:51 - 25 Feb 2024 13:55 #294360
by Nathan40
7i95 T for pwm 6 axis was created by Nathan40
Hi all. I was wondering if anyone can help with bit files for 6 axis PWM OUTPUTS all axis for 7i95t board and 5 axis BOB PWM Outputs for 7i95t boards. Thanks in advance
Last edit: 25 Feb 2024 13:55 by Nathan40.
25 Feb 2024 15:17 #294381
Replied by PCW on topic 7i95 T for pwm 6 axis
I can do that but need to know what I/O is desired on the 5ABOB.
25 Feb 2024 16:29 #294395
by Nathan40
Replied by Nathan40 on topic 7i95 T for pwm 6 axis
Thanks so much for your reply.
A. I want it replace all the stepgens 2,3, 4,5,6,7 with pwm in the 5 axis bob bit file found on the mesa website.
B. Also please share for 6 axis pwm bit file for all the stepgens.
25 Feb 2024 16:40 #294398
Still not clear to me.
Normally a 7I95T would have stepgens 0..5 on TB3 and TB4
Do you want these replaced with PWMgens?
Or do you want a standard 7I95T with 6 stepgens on TB3 and TB4
and a 5ABOB config for P1 with 6 PWMgens (no direction pins)
on DB25 pins 2,3,4,5,6,7?
25 Feb 2024 16:54 #294401
by Nathan40
I want two bit files.
A. That's correct. I want to replace all 6 stepgens with 6 pwmgens.
B. That's again correct. All stepgens changed to pwmgens for 6 axis (7i95T board) + 3 axis (BOB). In all 9 pwmgens.
25 Feb 2024 17:08 #294405
OK I can do this later today (flea market time now)
25 Feb 2024 17:16 #294407
by Nathan40
Ok..
25 Feb 2024 23:03 #294453
The following user(s) said Thank You: Nathan40
26 Feb 2024 08:56 - 26 Feb 2024 09:41 #294484
by Nathan40
Thank you so much. It works great.
For original 7i95 board (not the T or S version), please can you share a similar file with pwmgens on BOB and 6 axis . Can't find it on mesa website. Thanks!
Last edit: 26 Feb 2024 09:41 by Nathan40.
26 Feb 2024 17:03 #294535
Time to create page: 0.535 seconds
