Config Help for RPI4 + SKR E3 mini V2 + Remora or similar
26 Feb 2024 13:10 - 26 Feb 2024 13:12 #294513
by Steppge
Config Help for RPI4 + SKR E3 mini V2 + Remora or similar was created by Steppge
Hello everyone,
I need your help with my setup. LinuxCNC is already running on my Raspberry Pi 4, and I’ve also installed Remora. Unfortunately, I can’t find any information for my SKR E3 Mini board on where to connect the 5 cables coming from the Raspberry Pi. Somehow, I need to establish communication between the SKR Mini and the Raspberry Pi. The connections on the Raspberry Pi are clear, but where do I connect them on the SKR Mini? When I look at the source code on GitHub for Remora, I only find one entry for the SPI interface, but that seems to be related to the SD card. I’ve downloaded the pre-compiled firmware from Remora’s GitHub repository. Do I need to compile my own firmware to configure the SPI pins on EXP1?
It would be nice if you could help me further.
Last edit: 26 Feb 2024 13:12 by Steppge.
02 Mar 2024 10:53 #294897
Replied by andypugh on topic Config Help for RPI4 + SKR E3 mini V2 + Remora or similar
I have moved this into "Driver Boards" in the hope that it will get some attention.
02 Mar 2024 20:46 #294942
by cakeslob
Replied by cakeslob on topic Config Help for RPI4 + SKR E3 mini V2 + Remora or similar
where was it before? I think the issue is resolved, we took care of it on github
03 Mar 2024 13:52 #295044
It was in "basic configuration"
