7c81 x 7i85s firmware help
- weedsmoker
28 Feb 2024 06:22 #294666
by weedsmoker
7c81 x 7i85s firmware help was created by weedsmoker
what's up everyone I saw that PCW made some firmware to make this work the only problem is I need PWM instead of Step Direction. Is there any chance him or someone else could make me the bit file? if not any advice on how to do that myself would be greatly appreciated.
28 Feb 2024 19:09 - 28 Feb 2024 19:35 #294714
Replied by PCW on topic 7c81 x 7i85s firmware help
What specific I/O do you need?
Just a 7I85S with 4 sets of PWM/Dir instead of Step/Dir?
Last edit: 28 Feb 2024 19:35 by PCW.
- weedsmoker
28 Feb 2024 21:27 #294727
by weedsmoker
Replied by weedsmoker on topic 7c81 x 7i85s firmware help
yep I only plan on connecting one 7i85s and a single smart serial card
29 Feb 2024 01:29 #294745
4 PWM/DIR on first 7I85S, 4 stepgens on (probably unused) second
The following user(s) said Thank You: COFHAL
- weedsmoker
05 Mar 2024 04:29 #295189
by weedsmoker
sorry for the late reply, thanks for the firmware! I should finally have time to test it out tomorrow.
10 Mar 2024 01:11 #295547
by COFHAL
Replied by COFHAL on topic 7c81 x 7i85s firmware help
Could you help me with a firmware version to use pktUART on one of the RS 485/422 ports.
10 Mar 2024 02:40 #295555
Is this for just one 7I85S?
10 Mar 2024 16:43 #295583
by COFHAL
Not for direct connection at port 7c81
10 Mar 2024 16:58 #295587
I don't understand what firmware you want
Time to create page: 0.108 seconds
