How can I use a Mesa 5I25
- Holzwurm56
06 Mar 2024 13:56 #295319
by Holzwurm56
How can I use a Mesa 5I25 was created by Holzwurm56
Hello, I have 2 Mesa 5I25, they have 2 DB25 output sockets, similar to Lpt. Can I use these as 2 Lpt ports? Ev. with 2 breakout boards? Or do I definitely need an additional one Mesa card?
Greetings
Hans
Greetings
Hans
06 Mar 2024 14:23 - 06 Mar 2024 14:29 #295321
Replied by PCW on topic How can I use a Mesa 5I25
The 5I25 (and any 25 pin Mesa FPGA card) can be used with
normal parallel port breakout boards, with the correct firmware.
The following are all parallel port compatible configurations for the 5I25:
5i25_5ABOBx2.bit
5i25_benezanx2D.bit
5i25_bstechx2.bit
5i25_c11gx2.bit
5i25_c11x2.bit
5i25_dmmbob1x2.bit
5i25_g540x2.bit
5i25_hdbb2.bit
5i25_mx3660x2.bit
5i25_pmdx126x2.bit
5i25_r990x2.bit
I should note that the FPGA card does not function as a LPT port
with only simple I/O bits but rather the high speed operations
like step generation, encoder counting and PWM generation are
handled by FPGA hardware. These means things like the maximum step
rate are in the multi-MHz region.
5i25_5ABOBx2.bit
5i25_benezanx2D.bit
5i25_bstechx2.bit
5i25_c11gx2.bit
5i25_c11x2.bit
5i25_dmmbob1x2.bit
5i25_g540x2.bit
5i25_hdbb2.bit
5i25_mx3660x2.bit
5i25_pmdx126x2.bit
5i25_r990x2.bit
Last edit: 06 Mar 2024 14:29 by PCW.
Time to create page: 0.111 seconds
