How can I use the 48 I/O ports on the 7i76?
- kofsky0328
11 Mar 2024 01:50 - 11 Mar 2024 01:52 #295611
by kofsky0328
How can I use the 48 I/O ports on the 7i76? was created by kofsky0328
I use db25 to connect 7i95 and 7i76D. I configured the following information in the hal file: net flood-output iocontrol.0.coolant-flood => hm2_7i95.0.7i76.0.2.output-00, but starting linuxcnc shows that hm2_7i95.0.7i76.0.2.output-00 is not found.
Attached is the firmware and pinout I use
Last edit: 11 Mar 2024 01:52 by kofsky0328.
11 Mar 2024 01:58 #295612
Replied by PCW on topic How can I use the 48 I/O ports on the 7i76?
Looks like the 7I76 field I/O is on channel 1 with that firmware
so the names would be like:
hm2_7i95.0.7i76.0.1.output-00
- kofsky0328
11 Mar 2024 03:45 #295614
by kofsky0328
Replied by kofsky0328 on topic How can I use the 48 I/O ports on the 7i76?
The problem remains, it still shows that hm2_7i95.0.7i76.0.1.output-00 does not exist.
The attachment is the halcmd show pin file
- kofsky0328
11 Mar 2024 03:48 #295615
by kofsky0328
Is it possible that the problem is with the db25 cable?
11 Mar 2024 03:52 - 11 Mar 2024 03:58 #295616
Does the 7I76D have both field and 5V power?
(7I76D W2 Left, 7I95 W23 UP for 5V from 7I95)
The connecting cable should be flat a cable with
standard IDC (crimp-on) connectors
Last edit: 11 Mar 2024 03:58 by PCW.
- kofsky0328
11 Mar 2024 04:26 #295618
by kofsky0328
Yes, 7I76D W2 Left, 7I95 W23 UP, cr1 and cr2 led lights are all on.
11 Mar 2024 04:54 #295619
That should be correct
possibly cable?
Are 7I76 W3 and W1 left and VField > 10V?
possibly cable?
- kofsky0328
11 Mar 2024 05:37 #295620
by kofsky0328
Both w1 and w3 are on the left, and the VField input is 24V.
I'll order another cable to try.
- kofsky0328
13 Mar 2024 12:46 #295822
by kofsky0328
right! The problem is with the cable
and you are right, the 7i76 is on channel 1
Thank you very much for your advice
Time to create page: 0.311 seconds
