Need help with 7I96
- Holzwurm56
14 Mar 2024 18:57 #295912
by Holzwurm56
Need help with 7I96 was created by Holzwurm56
Hello, I have set up a network with the Mesa 7I96. I get a connection with ping. With Mesaflash I get an error message Board not found with --device ETHER or 7I96. Is there any way to determine the device name? Thanks Hans
14 Mar 2024 19:09 #295914
Replied by PCW on topic Need help with 7I96
What does the command (typed in a terminal)?
ip a
report?
ip a
report?
- Holzwurm56
15 Mar 2024 14:24 - 15 Mar 2024 14:26 #295966
by Holzwurm56
Replied by Holzwurm56 on topic Need help with 7I96
Here is the message in the terminal:
hansl@hans-d3240b1:~$ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host noprefixroute
2: enp3s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 90:1b:0e:2f:b5:14 brd ff:ff:ff:ff:ff:ff
inet 192.168.1.121/24 brd 192.168.1.255 scope global noprefixroute enp3s0
inet6 fe80::43be:87e0:558f:97da/64 scope link noprefixroute
3: enx000ec6f95e3f: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 00:0e:c6:f9:5e:3f brd ff:ff:ff:ff:ff:ff
inet 192.168.1.66/24 brd 192.168.1.255 scope global dynamic noprefixroute enx000ec6f95e3f
valid_lft 604320sec preferred_lft 604320sec
inet6 fe80::3ef5:cd04:e1e4:22ed/64 scope link noprefixroute
hansl@hans-d3240b1:~$ ping 192.168.1.121 -a
PING 192.168.1.121 (192.168.1.121) 56(84) bytes of data.
64 bytes from 192.168.1.121: icmp_seq=1 ttl=64 time=0.017 ms
64 bytes from 192.168.1.121: icmp_seq=2 ttl=64 time=0.028 ms
64 bytes from 192.168.1.121: icmp_seq=3 ttl=64 time=0.027 ms
64 bytes from 192.168.1.121: icmp_seq=4 ttl=64 time=0.026 ms
64 bytes from 192.168.1.121: icmp_seq=5 ttl=64 time=0.027 ms
64 bytes from 192.168.1.121: icmp_seq=6 ttl=64 time=0.029 ms
64 bytes from 192.168.1.121: icmp_seq=7 ttl=64 time=0.027 ms
64 bytes from 192.168.1.121: icmp_seq=8 ttl=64 time=0.026 ms
64 bytes from 192.168.1.121: icmp_seq=9 ttl=64 time=0.026 ms
64 bytes from 192.168.1.121: icmp_seq=10 ttl=64 time=0.027 ms
64 bytes from 192.168.1.121: icmp_seq=11 ttl=64 time=0.028 ms
^C
--- 192.168.1.121 ping statistics ---
11 packets transmitted, 11 received, 0% packet loss, time 10220ms
rtt min/avg/max/mdev = 0.017/0.026/0.029/0.003 ms
Last edit: 15 Mar 2024 14:26 by Holzwurm56.
15 Mar 2024 14:33 #295967
Looks like you don't have a proper static address setup for the 7I96
(You are not pinging the 7I96, but rather pinging your own PC)
Make sure that you setup a static IP address on the Ethernet channel
on the PC that is used for communicating with the 7I96. Note that
the PC's static address cannot match the 7I96 address. Also its preferable
to use the 10.10.10.10 address for the 7I96. To do this, set W5 down,
W6 up, and power cycle the 7I96. Then set the IP address of the PC's
interface that's connected to the 7I96 to 10.10.10.100.
- Holzwurm56
15 Mar 2024 17:54 #295984
by Holzwurm56
Hello PCW,
in what kind of way can i change the ip-address from the pc`s network adapter?
15 Mar 2024 18:01 #295985
You can either use the network manager
(There's an icon for this on the desktop)
and use the edit or create connection option
or you can edit the interfaces file as described
in the hm2_eth manual page:
man hm2_eth
man hm2_eth
- Holzwurm56
15 Mar 2024 18:17 #295986
by Holzwurm56
hansl@hans-d3240b1:~$ ip -c addr show enp3s0
inet 10.10.10.10/24 brd 10.10.10.255 scope global noprefixroute enp3s0
15 Mar 2024 18:21 #295987
The host IP address is set to the same as the 7I96, it must be different.
I suggest 10.10.10.100
- Holzwurm56
15 Mar 2024 20:55 #295996
by Holzwurm56
Hello PCW, Thank you. I only now understood that in the network manager you enter the address of the network adapter and not the address of the card. After making changes in the network manager, you have to restart the PC for the changes to take effect. Now it worked with mesaflash.
- Thank you received: 5972
16 Mar 2024 00:07 #296003
Replied by tommylight on topic Need help with 7I96
Not really, you can just click on network icon and click on "wired connection 1", it will disconnect and connect again with the new IP.After making changes in the network manager, you have to restart the PC for the changes to take effect.
Time to create page: 0.149 seconds
