- Hardware & Machines
- Driver Boards
- RV901T as MESA 7i90: Custom bitstream generation with PWMTag leads to error
03 Apr 2024 20:10 - 03 Apr 2024 20:56 #297536
Replied by PCW on topic RV901T as MESA 7i90: Custom bitstream generation with PWMTag leads to error
Still sounds like a clock setup error of some kind
maybe an introduced error in the DCM/BUFG setup
in the source.
The SPI clock is picky because it directly drives a GCLK
that runs SPI interface logic.
The multiplied clocks are available globally on a global clock spine
so the PWM pinout does not matter at all.
Can you post your .ucf file?
It may be that you have a conflict between the SPI GCLK and the DCM source
Taking a look at ug382.pdf might help
in the source.
Last edit: 03 Apr 2024 20:56 by PCW.
03 Apr 2024 22:21 #297547
by ago_tm
Replied by ago_tm on topic RV901T as MESA 7i90: Custom bitstream generation with PWMTag leads to error
Hello Peter,
github.com/golyakoff/hostmot2-rv901t-7i9...b/master/7i90spi.ucf
(this is the complete repo of original hostmot2 with separately commited my overrides).
Did I understand the key concept right?
There are two different time domains:
1. CLK (M9) 25 MHz from the own board oscillator
2. COM_SPICLK (P59) External from RPI (24 MHz if I coerrectly remember)
...and the RPI send commands over SPI for PWM, wh8ch is driving by CLK (as you say GCLK, but I do not understand the difference). And these time domains are not synchronized and they shouldn't be... right?
Is this right?
Sure, here it is:Can you post your .ucf file?
I started reading the manuals but not all is clear for me yet...It may be that you have a conflict between the SPI GCLK and the DCM source
Taking a look at ug382.pdf might helpc
Is this right?
03 Apr 2024 22:47 #297549
There are at least 3 clock domains: COM_SPI_CLK, CLOCKLOW,CLOCKHIGH
Any needed synchronization is done in the firmware.
Just as a test, you might would try moving the COM_SPI GCLK pin
to another GCLK. To me this seems like it may cause a conflict
Worst case since you cannot move the 25 MHz clock, you could try
eliminating the fclk DCM (and run everything at 100 MHz)
The following user(s) said Thank You: ago_tm
- Driver Boards
Time to create page: 0.172 seconds
