External step generator with ESP32 and ethernet communication.
01 Apr 2024 13:20 - 04 Apr 2024 11:27 #297369
by magos
Linuxcnc external step generator with esp32.4 axis, max 100khz step frequency .code:https://drive.google.com/file/d/16owzJZZRsMONBJ8dgtdx4Id6YElB448h/view?usp=sharing
Last edit: 04 Apr 2024 11:27 by magos.
The following user(s) said Thank You: tommylight, aparecido
- Thank you received: 5945
01 Apr 2024 16:18 #297383
Replied by tommylight on topic External step generator with ESP32 and ethernet communication.
Several versions of ESP32 now, so will this work on all of them?
02 Apr 2024 15:50 #297442
by magos
Replied by magos on topic External step generator with ESP32 and ethernet communication.
I haven't tested it, but I think it can work with any 2-core 240mhz version
02 Apr 2024 16:50 #297444
Oh good...well bad since i have 3 and 2 are already doing Flight Controller work on drones i am building, one flew a bit and broke propellers, twice, and the third is used for testing.
Can not find them here anymore...
02 Apr 2024 19:57 - 02 Apr 2024 20:29 #297455
by aparecido
Replied by aparecido on topic External step generator with ESP32 and ethernet communication.
That pcb in the first post, was it you who developed and assembled it? The pcb looks beautiful....
Haven't you tested the link files on any ESP32 model?
Last edit: 02 Apr 2024 20:29 by aparecido.
03 Apr 2024 13:54 #297503
by magos
yes, I designed the PCB and had the PCB manufactured by a company.
The linked files were tested with the module shown in the picture.
The following user(s) said Thank You: aparecido
03 Apr 2024 13:58 #297504
by aparecido
Wow, cool. Will you share the PCB files or is it just for your use? Abusing it a little, could you detail how you recorded the firmware on the esp32 and how you installed the driver and hal on linuxcnc using platformio??
03 Apr 2024 14:44 - 03 Apr 2024 14:53 #297508
by meister
Replied by meister on topic External step generator with ESP32 and ethernet communication.
This is now I think the 3rd stepgen firmware for ESP32
wouldn't it be good if you tried to combine your projects and make one of them, the differences shouldn't be that big and it would be easier for the users to decide.
You could also combine your resources better this way.
maybe even merge with remora.
but i can also understand if you want your own project
Last edit: 03 Apr 2024 14:53 by meister.
Time to create page: 0.309 seconds
