Stepper Motor to work like a DC
04 Apr 2024 08:50 #297563
by BonoCNC
Replied by BonoCNC on topic Stepper Motor to work like a DC
It's possible to make, via hal, my mesa board generate permanent steps to this motor, right after I turn on the machine?
04 Apr 2024 09:27 #297567
by BonoCNC
# Step Gen setup
setp hm2_7i96.0.stepgen.03.steplen 1000000 # Step length (nanoseconds)
setp hm2_7i96.0.stepgen.03.stepspace 1000000 # Step space (nanoseconds)
setp hm2_7i96.0.stepgen.03.maxaccel 500000 # Maximum acceleration (steps/second^2)
setp hm2_7i96.0.stepgen.03.maxvel 5000 # Maximum velocity (steps/second)
setp hm2_7i96.0.stepgen.03.step_type 0 # Regular step type
setp hm2_7i96.0.stepgen.03.dirsetup 2000000 # Direction setup time (nanoseconds)
setp hm2_7i96.0.stepgen.03.dirhold 2000000 # Direction hold time (nanoseconds)
setp hm2_7i96.0.stepgen.03.control-type 1 # Control type (1 for position control)
setp hm2_7i96.0.stepgen.03.enable True # Enable the step generator initially
# Set initial direction for motor rotation
setp hm2_7i96.0.stepgen.03.direction 0
# Connect Step Gen outputs to motor driver
net motor-step => hm2_7i96.0.stepgen.03.step
net motor-direction => hm2_7i96.0.stepgen.03.dir
Can it be with something like this?
04 Apr 2024 13:49 #297574
Replied by PCW on topic Stepper Motor to work like a DC
Try this:
setp hm2_7i96.0.stepgen.03.steplen 20000 # Step length (nanoseconds) 20 usec
setp hm2_7i96.0.stepgen.03.stepspace 20000 # Step space (nanoseconds) 20 usec
setp hm2_7i96.0.stepgen.03.maxaccel 50000 # Maximum acceleration (steps/second^2) so 1/10 second to full speed
setp hm2_7i96.0.stepgen.03.dirsetup 50000 # Direction setup time (nanoseconds) 50 usec
setp hm2_7i96.0.stepgen.03.dirhold 50000 # Direction hold time (nanoseconds) 00 usec
setp hm2_7i96.0.stepgen.03.control-type 1 # Control type (1 for velocity control)
setp hm2_7i96.0.stepgen.03.velocity 1000 # run forward
The following user(s) said Thank You: BonoCNC
04 Apr 2024 19:49 #297585
by BonoCNC
It is not necessary to link anything in .hal?
I will try with another board this way and simulate it.
For now I made it run with a arduino and it works fine and smooth.
04 Apr 2024 19:55 #297586
No links needed in hal, but ultimately to control the motors
you would have the velocity command linked to the control logic:
net motor_velocity hm2_7i96.0.stepgen.03.velocity <= control_velocity
04 Apr 2024 21:02 #297593
by BonoCNC
I will test it as soon as possible and share the results with you!
Time to create page: 0.515 seconds
