Mesa 7i96S SSERIAL and pktuart
10 Apr 2024 19:03 #297948
by lkavan
Mesa 7i96S SSERIAL and pktuart was created by lkavan
Hallo,
I have used in my machine Mesa 7i96S -> 7i74 -> 7i87 I have flashed 7i96s_7i74d.bin and everything works. But I also need to control the driver for tin pump motor (will be used as spindle) Driver is controlled with something like modbus. So, my idea was to use serial port on 7i96S Unfortunatelly, in HALshow I see there sserial port only and not pktuart. I have tried to flash 7i96sd_pktv2.bin but then 7i74 and 7i87 doesn't work. Is it possible to have 7i74 connected to 7i96s 's P1 and use serial port on TB2 as pktuart?
Thanx a lot for your help.
10 Apr 2024 19:40 #297950
Replied by PCW on topic Mesa 7i96S SSERIAL and pktuart
That may be quite a project, but I can add a PKTUart
to either the last channel of the 7I74 or the local port
on the 7I96S
on the 7I96S
The following user(s) said Thank You: lkavan
10 Apr 2024 19:57 #297954
by lkavan
Replied by lkavan on topic Mesa 7i96S SSERIAL and pktuart
Thanx for answer! I am changing control system in my selective soldering machine Inertec ELS 3.0 Machine is not bad, but original control system is horrible, LinuxCNC and Mesa will move the machine to 21.century
Well, it doesn't matter where pktuart will be, but I think, 7i96s local port will be better.
11 Apr 2024 01:05 #297977
7I96S configuration with PKTUART on the 7I96s and 7I74
(all sserial) on P1. Note that the P1 sserial port changed to
to port 0 (was port 1)
11 Apr 2024 05:53 #297990
by lkavan
Waw, you are really super fast! Thanx a lot, I will test it!
Thank you very much.
11 Apr 2024 18:29 #298018
by lkavan
I have flashed new software, changed sserial to 0 in HAL and it works. I have compiled and installed mesa_modbus with halcompile and loaded it in HAL. It seems it also works fine, I see modbus in HALshow. Great! But I don't know how to start modbus communication? Checked with oscilloscope, no communication on RS485. Can you help me what I am doing wrongly? Thanx.
11 Apr 2024 18:52 #298021
What error does modbus show?
Note that for 2 wire RS-485 on a 7I96S (pre REV E) ,
you this need for RS-485 communications to set
the undriven line state to idle:
1 GND
2 RX+,TX+ 330 Ohm pulldown to GND (1)
3 RX-,TX-
4 RX+,TX+
5 RX-,TX1- 330 Ohm pullup to 5V (6)
6 +5V
1 GND
3 RX-,TX-
4 RX+,TX+
6 +5V
11 Apr 2024 19:08 #298022
by lkavan
Yes, I have connected Rx and Tx according to 7i96S manual.
last_err pin is 0, fault also 0. I also compiled modbus with #define DEBUG 3 and no errors. Everything looks to be OK, but no communication.
11 Apr 2024 19:17 - 11 Apr 2024 19:18 #298023
Is the device you are connected to 2 wire or 4 wire?
if 2 wire RS-485, you will need to connect RX- to TX-
and RX+to TX+ and add the resistors shown in the previous
post. (the resistors need to be added in any case, 2 wire or 4 wire)
The fact that you get an error of 0 suggests that something
basic is unconnected in the hal file, is your setup something like this:
loadrt gs10 ports=hm2_7i96s.0.pktuart.0
addf gs10.00 servo-thread
setp gs10.00.baudrate 38400
setp gs10.00.address 1
Last edit: 11 Apr 2024 19:18 by PCW.
11 Apr 2024 19:28 #298024
by lkavan
I have 2 wire RS485. I have connected RX- to TX-
and RX+to TX+ and added resistors, but I have checked both TX+ and TX- with oscilloscope and no data are there.
I am not at my machine now, I will send you my hal and more info tomorrow. Thanx for support.
Time to create page: 0.132 seconds
