Mesa card 7i90 xilinx PhysDesignRules:2410
13 Apr 2024 14:14 - 13 Apr 2024 14:15 #298167
by telmoram
Mesa card 7i90 xilinx PhysDesignRules:2410 was created by telmoram
Hello, please can you help me, I make the config file and use ise desing 14.5 and got the warnig
PhysDesignRules:2410 - This design is using one or more 9K Block RAMs (RAMB8BWER). 9K Block RAM initialization data, both user defined and default, may be incorrect and should not be used. For more information, please reference Xilinx Answer Record 39999.
Does this warning affect normal operation?
Thanks.
Thanks.
Last edit: 13 Apr 2024 14:15 by telmoram.
13 Apr 2024 14:52 #298169
Replied by PCW on topic Mesa card 7i90 xilinx PhysDesignRules:2410
If you are using ISE >13.1 it only matters if encryption is used (its not)
I actually don't think it matters even on ISE < 13.2 as it seem more related
to Xilinx's core generator (which the source does not use for portability reasons)
13 Apr 2024 16:01 #298175
by telmoram
Replied by telmoram on topic Mesa card 7i90 xilinx PhysDesignRules:2410
ok, thanks.
Time to create page: 0.124 seconds
