inmux mesa card 7i90
14 Apr 2024 19:12 #298249
by telmoram
inmux mesa card 7i90 was created by telmoram
Hello, please help me with add inmux configuration 7i90 card, the P1 port its connected 7i48 card, the P2 connected hardware inmux for 16 inputs bits.
inmux addr0 to i/o 24
inmux addr1 to i/o 25
inmux addr2 to i/o 26
inmux addr3 to i/o 27
inmux data to i/o 28
Thanks.
Thanks.
14 Apr 2024 22:14 #298261
Replied by PCW on topic inmux mesa card 7i90
What is the host interface?
15 Apr 2024 13:07 #298281
by telmoram
Replied by telmoram on topic inmux mesa card 7i90
parallel port epp interface.
15 Apr 2024 14:17 - 15 Apr 2024 14:22 #298285
Last edit: 15 Apr 2024 14:22 by PCW.
The following user(s) said Thank You: telmoram
17 Apr 2024 20:40 #298490
by telmoram
hello, i am load the firmware but the inputs mux dont change the logic value, and use this circuit
the config files
please help me.
the config files
please help me.
17 Apr 2024 21:25 #298497
Ahh, I forgot that EPP interfaced cards cannot have module addresses > 0x7ffC
which leaves out most of the newer modules. Let me see if there's a handy alternate
address for inmux
address for inmux
17 Apr 2024 21:35 #298499
by telmoram
Ok, please.
17 Apr 2024 21:52 #298500
inmux moved from 0x81xx..0x84xx to 0x70xx..74xx so should work with EPP
17 Apr 2024 22:42 #298505
by telmoram
ok, i am test and the inmux with length its only 1, start linuxcnc show message inmux 0 scanrate to low, and the only input enabled read the data input.
17 Apr 2024 22:50 #298507
What does mesaflash [xxxxxxxx] --readhmid report?
Time to create page: 0.882 seconds
