7i76 encoder velocity
17 Apr 2024 14:00 #298442
by mariusl
Regards
Marius
www.bluearccnc.com
7i76 encoder velocity was created by mariusl
What does the 7i76 encoder velocity represent? I have a 1:1 encoder on my lathe spindle that has 2048 pulses per rev. So if the spindle is going at 1000rpm, what is the encoder velocity reading supposed to be?
Regards
Marius
www.bluearccnc.com
17 Apr 2024 15:05 #298453
Replied by PCW on topic 7i76 encoder velocity
If the encoder scale is correct (8192 for a 2048 PPR encoder),
the velocity is in RPS (or RPM on the velocity-rpm pin)
17 Apr 2024 16:32 #298463
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic 7i76 encoder velocity
So if I see a velocity of 80 for about 1000 rpm it is not good? What can influence that output?
Regards
Marius
www.bluearccnc.com
17 Apr 2024 17:13 - 17 Apr 2024 17:21 #298473
Is 80 the RPS or RPM pin?
Incorrect encoder scaling could be the issue
Is the encoder 2048 PPR (8192 counts per revolution in quadrature)
or 2048 counts per revolution?
Last edit: 17 Apr 2024 17:21 by PCW.
18 Apr 2024 05:01 #298529
by mariusl
Regards
Marius
www.bluearccnc.com
That is the RPS reading. It's a quadrature encoder so I would imagine it is 2048 PPR.
Regards
Marius
www.bluearccnc.com
18 Apr 2024 05:29 #298530
If its a 2048 PPR the encoder, the scale should be 8192
If you were off by a factor of 4 like this then this would
80 RPS would become 20 RPS or 1200 RPM which is close.
I would watch the raw encoder counts and see how many
counts you get for 1 full turn (to set the encoder scale correctly)
The following user(s) said Thank You: mariusl
18 Apr 2024 06:10 #298532
by mariusl
Regards
Marius
www.bluearccnc.com
Thanks Peter. That makes sense now. The scaling was out by a factor of 4.
Regards
Marius
www.bluearccnc.com
