MesaTool 2 Instal Issue
- Project_Hopeless
- Topic Author
- Thank you received: 9
06 May 2024 02:21 #299874
by Project_Hopeless
MesaTool 2 Instal Issue was created by Project_Hopeless
I've downloaded the package mesact_2.1.3_amd64.deb. I installed using GDebi package installer, but nothing seems to happen. Terminal does not open up and scroll through the various packages. I can't get the tool to run from terminal, i get the error, bash: mesact: command not found.
Any ideas.
Any ideas.
- Thank you received: 5983
06 May 2024 08:33 #299911
Replied by tommylight on topic MesaTool 2 Instal Issue
In a terminal, type mesa and press the TAB key, see if it shows it then press enter.
- Project_Hopeless
- Topic Author
06 May 2024 22:11 - 06 May 2024 22:12 #299974
by Project_Hopeless
Replied by Project_Hopeless on topic MesaTool 2 Instal Issue
All that comes up is... mesaflash and mesa-overlay-control.py
Last edit: 06 May 2024 22:12 by Project_Hopeless.
06 May 2024 22:20 #299975
Replied by PCW on topic MesaTool 2 Instal Issue
Looks like you have not installed mesact
what does
locate mesact
report?
what does
locate mesact
report?
- Project_Hopeless
- Topic Author
06 May 2024 22:56 - 06 May 2024 22:57 #299976
by Project_Hopeless
what does
locate mesact
report?
From the terminal nothing, not even a not found kind of message.
Last edit: 06 May 2024 22:57 by Project_Hopeless.
- Project_Hopeless
- Topic Author
06 May 2024 23:01 #299977
by Project_Hopeless
I'm not Linux savvy but I'm not even being asked to enter my usr or pwd like I usually do trying to install the package. Is there maybe a permission thing going on.
06 May 2024 23:04 #299978
What happens when you double click on the downloaded file?
- Project_Hopeless
- Topic Author
06 May 2024 23:47 - 07 May 2024 00:07 #299981
by Project_Hopeless
It opens up "Package Installer - mesact""
Then nothing happens after that.
Last edit: 07 May 2024 00:07 by Project_Hopeless.
07 May 2024 08:11 #300015
That should have been the first thing you said.
Open a terminal, navigate to where the downloaded file is located and type
sudo gdebi Name_of_file.deb
Replace name of file with actual file name, that should show more info.
The following user(s) said Thank You: Project_Hopeless
- Project_Hopeless
- Topic Author
07 May 2024 23:00 #300074
by Project_Hopeless
That did the trick Thank-you!
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Mesa Configuration Tools for LinuxCNC
This software can create configuration files used by LinuxCNC to
control 5i25/6i25, 7i76e, 7i80, 7i92, 7i95, 7i95T, 7i96, 7i96S, 7i97 and 7i98
Mesa Electronics motion control boards, smart serial boards and daughter cards.
Do you want to install the software package? [y/N]:y
/usr/bin/gdebi:113: FutureWarning: Possible nested set at position 1
c = findall("[[(](\S+)/\S+[])]", msg)[0].lower()
Selecting previously unselected package mesact.
(Reading database ... 201300 files and directories currently installed.)
Preparing to unpack mesact_2.1.2_amd64.deb ...
Unpacking mesact (2.1.2) ...
Setting up mesact (2.1.2) ...
Processing triggers for desktop-file-utils (0.26-1) ...
Processing triggers for mailcap (3.70+nmu1) ...
Processing triggers for man-db (2.11.2-2) ...
Time to create page: 0.245 seconds
