LinuxCNC 2.9.2 has been released
26 Dec 2023 02:15 #289056
LinuxCNC 2.9.2 has been released was created by andypugh
LinuxCNC 2.9.2 has been released. This is a bugfix release, with the
most obvious change being that run-from-line in the Axis interface
should now be working again.
Packages have been prepared for:
Buster - uspace - amd64 (PC) armhf (Pi) arm64 (Pi with 64-bit kernels)
Buster - RTAI - amd64
Bullseye - uspace - ams64 (only)
Bookworm - uspace - amd64, arm64
Bookworm - RTAI - amd64
For existing users of 2.9.1 on the above platforms this should be
offered as an automatic update.
If anyone badly needs Bullseye debs for RTAI or arm64 / armhf then let
me know. (all but the amd64 uspace builds have to be manually created)
Contributors to this release are:
Alec Ari
andypugh
c-morley
dps.lwk
Greg Carl
Hans Unzner
Håvard F. Aasen
Moses McKnight
Norbert Schechner
Peter Wallace
Petter Reinholdtsen
Phillip Carter
Rene Hopf
Sebastian Kuzminsky
Sigma1912
Steffen Moeller
Full changelog:
* Add dither option to PWMGen for improved analog resolution
* axis: Fix run-from-line - bug #2771
* debian/changelog: fix epoch & white space
* deleted craftsman gui, as it is not python 2 nor gtk3 based and
not mantained for a long period
* deleted gmoccapy plasma, as glade panels are still in gtk2
* Docs: Many updates
* fix hardcoded description in Spanish language Closes: #1057312
* Fixes warnings for possible string truncation with strncpy()
* Gladevcp: fix error on missing filter program
* gmoccapy: Fixed Inappropriate Logical Expression (#2769)
* gmoccapy: fixes error when trying to hide the turtle-jog button in gmoccapy
* hal_glib -add get_linuxcnc_version function
* Increase size of STACK_ENTRY_LEN
* Merge pull request #2567 from petterreinholdtsen/2.9-gcode-g38.2
* Merge pull request #2757 from dpslwk/patch-1
* Merge pull request #2761 from LinuxCNC/s_code_fix
* Merge pull request #2765 from LinuxCNC/pncconf_fix_missing_ssport
* Merge pull request #2772 from hansu/fix-debian-1057312
* Merge pull request #2775 from smoe/translation_breaking_po4a
* Merge pull request #2782 from Sigma1912/patch-2
* Merge pull request #2783 from Sigma1912/patch-3
* Merge pull request #2790 from havardAasen/fix-string-truncation
* Merge pull request #2791 from havardAasen/havardAasen-patch-1
* Merge pull request #2795 from havardAasen/build-dependency
* motion control: allow the spindle to be on with speed of 0
* motion: fix brake/direction setting when S command is sent.
* motion.c: Improve handling of misc_error pin names See #2780 #2773
* pmx483-test: change package message to python3-serial
* pncconf - change spindle stepgen enable from spindle-enable to machine-is-on
* pncconf -fix HAL load command for 2 serialports
* qtaxis -add version string to log
* qtdragon -add a default 'factor' to avoid error message
* qtdragon_hd -fix stylesheets for 5 axis, adjust qtdragon.ui
* qtdragon/hd -add version messages to about and log
* qtdragon/hd -fix spindle override quick setting buttons
* qtdragon/hd -update version after fixing probing bug
* qtplasmac docs: update python serial version
* qtplasmac: fix 5th axis buttons
* qtplasmac: fix case switching in run from line
* qtplasmac: fix gcode filter comments error
* qtplasmac: fix imperial cut parameter ranges
* qtplasmac: fix power button styling
* qtplasmac: fix removal of temporary materials in run from line
* qtplasmac: fix run from line code restoration
* qtplasmac: fix string formatting and version check
* qtplasmac: fix translation error in pmx485_check
* qtplasmac: fix updater typo, document update_log.txt
* qtplasmac: prevent extra temporary material addition from conversational
* qtplasmac: rework versioning due to master branch diverging
* qtvcp -add vismach obj files to search, change path from debug to info
* qtvcp -auto_height: improve logging/status output
* qtvcp -copy panel: update to check for the qtvcp/screens or panels path
* qtvcp -docs: the 'copy_dialog' panel changed to just 'copy'
* qtvcp -notify: silence annoying error message
* qtvcp -probe routines:fix spindle start on error or abort
* qtvcp -touchoff_subprogram: fix typos so it works properly.
* Restore functionality of NO_PROBE ini settings
* revert changes for strncat()
* RTAI: Fix build against RTAI+GNU11
* snprintf uses %d on a double (issue 2784)
* stdglue.py: Fix error on loading stdglue remaps using an R word.
(The previous code errored on attempted comparison between dict and
float)
* tests: status.state should be checked against command execution status
* Update build-dependency for OpenGL
* Update combi_dro.py
Alec Ari
andypugh
c-morley
dps.lwk
Greg Carl
Hans Unzner
Håvard F. Aasen
Moses McKnight
Norbert Schechner
Peter Wallace
Petter Reinholdtsen
Phillip Carter
Rene Hopf
Sebastian Kuzminsky
Sigma1912
Steffen Moeller
Full changelog:
float)
The following user(s) said Thank You: tommylight, JT
Time to create page: 0.181 seconds
