Mori MVJR Build Log
01 Aug 2011 06:59 - 01 Aug 2011 07:06 #12073 by schmidtmotorworks
I have started an EMC2 build for a Mori Seiki MVJR.
The machine was built in 1986 with an MX2 Control.
I would like to start by thanking everyone that has contributed to the software and all the help that is provided here on this forum.
With my limited electronics experience but good documentation skills, I hope to give back by logging the steps of my build in a way that anyone can follow.
The attached image is a CAD model I made of the chassis, with mother board and Mesa cards and Honda connectors to fit the existing cable ends..
My goal at this point is to come as close as possible to bolting this control in and running it, (OK it's a fantasy)
The parts list so far is:
Mesa:
1 x 5i23
1x 7i48
2x 7i64
1x 7i44 RJ45
2x Custom cables (ask Mesa, the know what you need)
Intel Mother Board:
1X D510MO + 1gb memory
Hard Drive
32 GB solid state
Zumax Power Supply
ZU-400W ATX12V
If anyone needs the following let me know and I can post them:
Original Ladder diagram for the machine and control
CAD models of the parts (close enough for positioning and mounting
I'm nearing the point of pulling the existing control, if you have any advice, please post it.
Last edit: 01 Aug 2011 07:06 by schmidtmotorworks. Reason: Spelling
01 Aug 2011 11:57 #12078 by BigJohnT
Replied by BigJohnT on topic Re:Mori MVJR Build Log
Is the 7i44 and 7i48 supported by EMC now?
Why use the 5i23 over the 5i20?
02 Aug 2011 05:47 #12120 by schmidtmotorworks
My understanding is that 7I44 and 7I48 will be supported by 2.5.
My hardware choice was made drafting behind the research, advice and conclusions the were made on Corys MV35/40 thread.
I had Mesa review the list and they thought it was OK too.
02 Aug 2011 05:50 - 02 Aug 2011 05:51 #12121 by schmidtmotorworks
Today I began a spreadsheet listing all the wires and their connections found in the control panel diagrams.
It looks like about 5 evenings work at the moment.
My hope/expectation is that this will make an orderly process of wiring the connectors to the Mesa boards.
Last edit: 02 Aug 2011 05:51 by schmidtmotorworks.
02 Aug 2011 11:53 - 02 Aug 2011 11:55 #12124 by BigJohnT
I missed that about the 7i44 and 7i48, stuff happens so fast with Mesa hardware it is hard to keep up.
I do remember when I inquired about the 5i23 vs the 5i20 I was told that the 5i23 when used with EMC was an overkill and the extra 200 gates would not be used. But things might have changed and I don't know about it... the only advantage I see is the 5i23 card is shorter than the 5i20 otherwise they both have the same number of I/O.
Last edit: 02 Aug 2011 11:55 by BigJohnT.
02 Aug 2011 13:08 #12125 by andypugh
Replied by andypugh on topic Re:Mori MVJR Build Log
7i48 needed muxed encoders, which were introduced almost a year ago:
git.linuxcnc.org/gitweb?p=emc2.git;a=com...3a87044bd62e1ade5326
7i44 is just a breakout from 50-pin header to 8x RG sockets.
7i64 support is in the 2.5 branch.
git.linuxcnc.org/gitweb?p=emc2.git;a=com...bfe9f9f70cef6c0a86af
03 Aug 2011 16:24 #12160 by clkeck1
Replied by clkeck1 on topic Re:Mori MVJR Build Log
Looks good Jon. You are a little further along then me. My Honda connectors just showed up[ from bulgaria today.
You may want to entertain the idea of putting one of the 7i64s in the control station. That way you only have to run 1 rj45 cable instead of 2 wires for each input and output function.
Cory
04 Aug 2011 04:55 #12167 by schmidtmotorworks
Cory
Presently I am looking into the possibility of leaving the existing wires between the cabinet and the control intact. Not sure if that will work out or not. I guess it depends somewhat on what monitor I use.
05 Aug 2011 06:02 - 05 Aug 2011 06:02 #12204 by schmidtmotorworks
Now that you mention those connectors, they have very small pins and I'm wondering how best to connect the wires to them?
Solder them directly?
Is there some kind of connector I can use?
Also, any good ideas about how to label the wires?
Last edit: 05 Aug 2011 06:02 by schmidtmotorworks.
05 Aug 2011 12:34 #12212 by clkeck1
cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&i...geName=STRK:MEWNX:IT
I got these ones that have a loop to wire thru before you solder. I'm not sure how to handle the straighht pins.
Moderators: cncbasher
Time to create page: 0.228 seconds
