Mori MVJR Build Log
25 Dec 2011 12:28 #15995
by BigJohnT
Replied by BigJohnT on topic Re:Mori MVJR Build Log
Take a look for
motion.spindle-at-speed
Motion will pause until this pin is TRUE, under the following conditions: before the first feed move after each spindle start or speed change; before the start of every chain of spindle-synchronized moves; and if in CSS mode, at every rapid->feed transition.
- schmidtmotorworks
- Thank you received: 6
16 Jan 2012 18:53 #16824
by schmidtmotorworks
Replied by schmidtmotorworks on topic Re:Mori MVJR Build Log
Yesterday, I ran my first real program, succesfully and completed 40 parts, I'm using AXIS and like it a lot.
The only major thing left unfinished is the tool changer.
If anyone is interested in doing a paid project to do the tool changer coding, contact me at:
This email address is being protected from spambots. You need JavaScript enabled to view it.
16 Jan 2012 19:27 #16825
by robh
Replied by robh on topic Re:Mori MVJR Build Log
what type of changer is it?
u might be able to steel my hal & classicladder setup if it can be changed dout there isalot to change probly
is it twin arm or umbrella?
rob
rob
- schmidtmotorworks
17 Jan 2012 05:07 #16835
robh wrote:
It is a twin arm.
I would sure be happy to see any examples.
rob
It is a twin arm.
17 Jan 2012 12:05 #16843
by BigJohnT
While not a twin arm tool changer here is my CHNC.
gnipsel.com/shop/hardinge/hardinge.xhtml
Just download the config files to see the ladder.
Does your spindle need to orientate to a special place to change the tool?
- schmidtmotorworks
17 Jan 2012 16:28 #16852
Thanks for the help.
Yes the spindle does need to orient.
I will start trying to understand them tonight.
I think I will set up my home computer to do the classic ladder work so that I don't get distracted with all the work I need to do in the shop. Do you know if it is possible to do classic ladder work using the live cd or do I need to make my machine dual boot and do a full install?
17 Jan 2012 17:14 #16855
by BigJohnT
At least you can glean the handshaking with tool change request and tool change finished from my example.
I don't know if it is possible to save anything from the LiveCD but you could do a virtual box and install the LiveCD there or do the dual boot.
Does your spindle use an encoder with index to orientate or does it have some kind of solid stop?
Moderators: cncbasher
Time to create page: 0.481 seconds
