hello, I'm new, I need to do a CNC lathe, and no w
14 Jan 2010 01:07 - 17 Jan 2010 00:18 #1511
by hleonardo
hello, I'm new, I need to do a CNC lathe, and no w was created by hleonardo
someone able to run a lathe cnc
The mechanical part is already settled, do not like the electronics,
Components that I buy?
TIP anyone know where I can buy the information components
the other problem I have is not how to configure the pc
are working with cad cam software, is working with lathes cnc, cnc machine but I have to work
anyone can help me
thank you very much
I need to machine steel:
5hp around the plate, 100 to 2000 rpm, I think direct current motor, to enable threading.
advance: 500mm/min, with tolerance of 0.02 mm, on the axes.
I just need the circuits, and components.
anyone can help me
thank you very much
Last edit: 17 Jan 2010 00:18 by hleonardo.
16 Jan 2010 22:49 #1522
by robh
Replied by robh on topic Re:hello, I'm new, I need to do a CNC lathe, and no w
what kind of lathe/setup is this for
need some more information before some one can help in more details here
is it Servo system or stepper or other?
buy the information components?
not sure what your asking here, where to find technical info or other?
for EMC setup you need to read through the manuals
for your machine you need the hardware manuals learn how things connect and work before you do any work.
17 Jan 2010 00:20 #1523
by hleonardo
Replied by hleonardo on topic Re:hello, I'm new, I need to do a CNC lathe, and no w
thanks for answering
Moderators: cncbasher
