What kind of limit/home switches so you guys use?
10 Mar 2010 19:57 #2266
by Davenc
What kind of limit/home switches so you guys use? was created by Davenc
The magnetic ones or the standard mechanical ones? I've seen the small ones on ebay at $16 for 20 of them. Any of you guys have pictures of how you mounted them? I'm planning on using the standard configuration that is in the documentation for EMC2 on wiki which uses a separate pin on the parrallel port for each axis.
10 Mar 2010 20:54 #2267
by tenaja
Replied by tenaja on topic Re:What kind of limit/home switches so you guys use?
If you need safety, you need to use normally closed switches. That way if the wire breaks, it fails to a safe mode rather than allowing a dangerous crash.
Having said that, I've used both kinds. Recently I got some cheap SMC reed switches with LED's in them. They are normally open, but for the Sherline lathe I am not concerned.
10 Mar 2010 21:42 #2268
by alex_joni
Replied by alex_joni on topic Re:What kind of limit/home switches so you guys use?
don't forget optical ones..
10 Mar 2010 22:51 - 11 Mar 2010 02:38 #2269
by tenaja
Optical switches are great in a clean environment--I wired one up a couple months ago. If the lighting is not consistent or if dirt or machining chips can get on it, you may have inconsistent results.
Last edit: 11 Mar 2010 02:38 by tenaja.
11 Mar 2010 13:08 - 11 Mar 2010 13:09 #2276
by BigJohnT
Replied by BigJohnT on topic Re:What kind of limit/home switches so you guys use?
Last edit: 11 Mar 2010 13:09 by BigJohnT.
Moderators: cncbasher
Time to create page: 0.133 seconds
